No HDMI Display need help with correct uEnv.txt settings
if you are using a hdmi to dvi setup then getting the monitor functional will take some experimenting with settings and depending on your setup may not work. i would suggest trying the latest arch linux build for pine64. it comes with xfce desktop installed. it will help narrow what the problem may be if you test that build.
RE: No HDMI Display need help with correct uEnv.txt settings - by dkryder - 01-11-2018, 03:13 AM
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 4,053 04-19-2019, 08:26 AM
Last Post: psychedup
  lcd touch screen and hdmi output moreaujacky 2 5,049 10-24-2018, 07:24 AM
Last Post: lisanke
  HDMI Compatability rahlquist 5 8,203 07-29-2017, 02:32 AM
Last Post: qwerty2002
  Ongoing HDMI limited compatability rahlquist 39 50,260 05-21-2017, 12:59 PM
Last Post: lbdroid
  No HDMI Output martinarcher 2 6,647 04-28-2017, 07:05 AM
Last Post: martinarcher
Rainbow Pine64 + waveshare display? iPhyse 4 6,932 10-12-2016, 04:43 PM
Last Post: hamzahbondok
  Switching from touchscreen to HDMI AUDIOTEK 10 12,267 08-11-2016, 07:41 PM
Last Post: MarkHaysHarris777
  4K HDMI video output medapeta 3 6,688 06-10-2016, 04:36 PM
Last Post: shinobi
Sad display problem florianl 5 7,287 04-29-2016, 08:53 AM
Last Post: Luke
  HDMI Issue... LeRoms77 4 7,304 04-19-2016, 02:11 AM
Last Post: LeRoms77
