Guide - Raid Array (Raid 0)
Information
Preface
In this guide, I will be showing how to create a raid array, using the raid 0 configuration. This allows you to have maximize storage available, however it comes at the risk of data loss in case of hardware failure.
[Image: DifficultBitterAndeancondor-size_restricted.gif]
It also has the benefit of having really pretty "blinkenlights" effect when the USB drives are being accessed.
Prerequisites
ROCK64 board running Debian or Ubuntu, connected to the local network
Access to terminal, either locally or via SSH
At least 2 Flash drives (or hard drives)
Recommended: USB Hub, for ease of access.
___________________
Make sure your software and repositories are up to date:
sudo apt update && sudo apt upgrade
Next, we install the mdadm package, used to monitor and implement software raid in linux:
sudo apt install mdadm
After installing it, we can get our flashdrives and plug them directly into the ROCK64 board, or onto a USB hub and plug that into the board.
The USB drives that I used were previously erased by me, and thus, don't have any partitions. We can confirm that they've been detected by the system by issuing the "lsblk" command, showing the attached blocked devices. In my case, they are sdb, sdc, and sdd:
[Image: fJUNTyv.png]
Since we can see the 3 (in my case) flash drives recognized by the system, we can now proceed and start to create a new raid array.
WARNING: BE VERY CAREFUL WITH THE FOLLOWING STEPS AND DOUBLE CHECK, USING THE WRONG NAMES COULD LEAD TO DATA LOSS
sudo mdadm --create --verbose /dev/md0 --level=0 --raid-devices=3 /dev/sd{b,c,d}
"--level=0" denotes the raid level, or the type of raid. "--raid-devices" flag states the number of devices. The last argument "/dev/sd{b,c,d}" is simply an easier way of saying "/dev/sdb /dev/sdc /dev/sdd" without having to type it all out (called Brace Expansion).
[Image: LAWNB9K.png]
After the Array is created, you can invoke the "lsblk" command, to see the status of the USB drives. Notice that all three drives (sdb,sdc,sdd) are part of the partition (md0) and that the partition size is larger than the size of the physical disk:
[Image: RejMu5C.png]
Now, we can simply create a partition on the raid array, and mount it to a suitable location.
I created an ext4 partition on my Raid array:
sudo mkfs.ext4 -F /dev/md0
Then, I created a mountpoint for my new Ext4 partition, and mounted it:
sudo mkdir -p /mnt/md0
sudo mount /dev/md0 /mnt/md0
I also used this as an opportunity to check my RAID was succesfully created by checking the /proc/mdstat file (though, it was my mistake, I should have done this step right after creating the array.
[Image: LPIHkQk.png?1]
Now that the RAID device is mounted, we can use the chown command to assume ownership of it so that we can write to it:
sudo chown -R rock64: /mnt/md0/
Again, this might vary depending on your username and mount location.
Thats all there is to it! We're done! You should be able to access that device under your mountpoint. We can confirm that the RAID array is mounted using either "lsblk" or "df -h":
[Image: 5NRL2F7.png]
[Image: nM0D8aD.png]
Guide - Raid Array (Raid 0) - by Ptheven - 10-07-2017, 09:22 AM
  Beginners Guide: Migrating to SSD rontant 18 40,277 01-19-2022, 09:30 AM
Last Post: Ellesar Dragon
Information Beginners Guide: Adding USB Storage, Linux Formatting and Permissions Ptheven 4 12,346 03-06-2021, 01:49 PM
Last Post: helpmerock
  Step by step guide PXE diskless configuration. burglar_ot 13 36,014 11-01-2020, 11:26 PM
Last Post: michael.gruner
Thumbs Up A guide for how I made RetroPie, RetroArch, and EmulationStation Work on the Rock64 Mrfixit2001 4 16,180 12-17-2018, 03:52 AM
Last Post: va88
  Guide - XRDP - Debian Stretch / Ubuntu Xenial / OMV S3phi40T 3 14,057 05-05-2018, 06:08 AM
Last Post: S3phi40T
Information Guide - Setting up a NFS Share Ptheven 0 5,526 09-26-2017, 04:44 AM
Last Post: Ptheven
  Guide - Setting up a SMB(Windows) file server Ptheven 0 12,652 08-21-2017, 08:54 AM
Last Post: Ptheven
Information Beginners Guide: Locating your board, connecting to it. Ptheven 5 16,027 08-21-2017, 04:12 AM
Last Post: Ptheven
