Can't boot headless after running update_uboot.sh
I've got a Pine64 2GB from a friend, with the original USB power supply. I've flashed Linux onto a quality SD card using Etcher on Linux.
Pine64 boots fine, I can login with SSH and do all the things I want to do. I'm running headless.
If I run the update_uboot.sh script, then I can no longer boot headless. I've tested the Debian and Xenial Base images. I don't have a serial console, so I can't see if there are any boot messages. All I can tell is that I can no longer connect via SSH, and it doesn't appear in my router's list of connected devices. If I connect a monitor before powering up it boots just fine.
Can't boot headless after running update_uboot.sh - by Borglesnorgle Williams - 08-17-2017, 03:04 AM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,163 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Secure boot & OTP efuse program devangpanchal90 0 2,596 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  boot process for pine a64 awaysu 1 4,400 01-24-2018, 05:09 AM
Last Post: xalius
  Fedora Running On Pine64! cztian 26 36,968 10-26-2017, 05:51 PM
Last Post: gregjo
Exclamation Pine A64 Plus Fails to Boot grobbs 35 41,108 06-28-2017, 08:53 AM
Last Post: sarav_sara
  Boot issues: What todo when you muck up your FSTAB file Dagremote 1 3,768 04-16-2017, 10:28 PM
Last Post: pfeerick
Question Pine64 cannot boot jamiechang917 6 9,639 04-16-2017, 10:21 PM
Last Post: pfeerick
  U-Boot for A64 git longsleep 38 68,850 03-21-2017, 01:59 PM
Last Post: longsleep
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 6,751 03-20-2017, 03:59 PM
Last Post: rgdonato
  USB OTG Boot devilsclaw 25 39,047 03-01-2017, 03:22 PM
Last Post: CaptainZalo
