Boot from SD card / boot options
(11-25-2019, 11:13 AM)ryannshit Wrote:
(11-25-2019, 07:35 AM)xalius Wrote: Have you tried reseating the ffc cable that goes to the daughterboard with the sdcard/headphone jack? Does the sdcard work if you boot from eMMC? Do you have a serial console dongle so you can see what is going on while trying to boot?
I have not tried reseating. The SD Card shows up in the GUI as PINEBOOKneon for instance.  I ran the widevine and mrfixit update scripts and still cannot boot to SD.
Just to clarify, is this problem occuring on a Pinebook or Pinebook Pro?
Boot from SD card / boot options - by lodger - 06-16-2017, 11:56 AM
RE: Boot from SD card / boot options - by xalius - 06-16-2017, 02:54 PM
RE: Boot from SD card / boot options - by lodger - 06-17-2017, 04:45 AM
RE: Boot from SD card / boot options - by Luke - 05-17-2019, 09:05 AM
RE: Boot from SD card / boot options - by giel - 05-23-2019, 06:09 AM
RE: Boot from SD card / boot options - by giel - 05-27-2019, 08:23 AM
RE: Boot from SD card / boot options - by xalius - 11-25-2019, 07:35 AM
RE: Boot from SD card / boot options - by tophneal - 11-26-2019, 07:14 AM
  Booting with TOC0 u-boot -- should it work? dreadbit 0 750 11-24-2022, 10:19 AM
Last Post: dreadbit
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,742 12-07-2020, 04:02 PM
Last Post: SanjevR
  eMMC boot linux distros for Pinebook. frank-zappa 14 20,751 09-06-2019, 08:39 AM
Last Post: frank-zappa
  Link to 11.6 pinebook mainboard schematics for removing wifi card Shoananas 0 1,984 05-19-2019, 04:46 PM
Last Post: Shoananas
  Is it possible to choose between SD/eMMC boot programmatically? UltraBloxX 2 4,816 01-28-2019, 11:41 AM
Last Post: UltraBloxX
  [SOLVED] Can't boot when SD card inserted jschall 5 7,762 11-17-2018, 11:53 AM
Last Post: jschall
  Boot from MicroSD ramboton 3 5,393 11-16-2018, 06:04 PM
Last Post: Luke
  How to mount new microSD card? jschall 8 8,764 11-12-2018, 11:04 AM
Last Post: jschall
  Move Installation from SD Card to eMMC? soupbowl 4 8,791 11-10-2018, 10:47 AM
Last Post: acruhl
  Dual Boot on eMMC? d97 1 3,586 08-30-2017, 10:04 AM
Last Post: abrmx
