Boot issues: What todo when you muck up your FSTAB file
Greetings:
New Piner and forum member. Was adding an external previously formatted NTFS 1TB drive, and had issues getting read/write access. Managed to get the system into a non boot state. In the end, I managed to resolve the boot issue, but chose to switch to a new drive formatted with EXT3. No probs since.
In the interest of helping others, with a similar issue, here’s what I ended up doing. Will leave out what didn’t work, to keep the post shorter.
Didn’t have an actual spare Linux system, so I used a Vmware desktop system running Kali, running on my Win 10 laptop. The VM recognized USB devices, but didn’t recognize the larger micro USB caddy the memory card came with. Had to run out and by a new memory card that shipped with both a USB and larger memory card reader.
The Pine64 micro SD card mounted automatically on the Kali VM, and provided full access to the system folders. Ending the /etc/fstab file took seconds and Pine booted afterwards.
Thanks to some folks on the IRC channel for offering suggestions, everything came together in the end.
For those who have read this far, in the interest of sharing what my Pine is doing …
1.) Security system with Zoneminder
Running 3 cameras for now. External drive setup with symbolic links to hold the video.
2.) Local cloud with Owncloud
External drive setup as the main repository.
So far very positive things to say about the community and the product.
W.
Boot issues: What todo when you muck up your FSTAB file - by Dagremote - 04-16-2017, 09:08 AM
  Need Asound.state file with mic enabled muromec 1 584 01-15-2024, 09:38 AM
Last Post: Bebert
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,044 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Issues with both Deb and Ubuntu germanshep 0 2,488 08-28-2018, 05:47 PM
Last Post: germanshep
  Secure boot & OTP efuse program devangpanchal90 0 2,573 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  boot process for pine a64 awaysu 1 4,361 01-24-2018, 05:09 AM
Last Post: xalius
  Can't boot headless after running update_uboot.sh Borglesnorgle Williams 2 4,202 08-17-2017, 04:08 AM
Last Post: Borglesnorgle Williams
Exclamation Pine A64 Plus Fails to Boot grobbs 35 40,442 06-28-2017, 08:53 AM
Last Post: sarav_sara
Question Pine64 cannot boot jamiechang917 6 9,521 04-16-2017, 10:21 PM
Last Post: pfeerick
  U-Boot for A64 git longsleep 38 68,302 03-21-2017, 01:59 PM
Last Post: longsleep
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 6,670 03-20-2017, 03:59 PM
Last Post: rgdonato
