Arch Linux image (BSP Kernel)
Well, you wanted images - here we go. If you are brave you can run Linux on your Pine64 now. **This image is intended for developers. If you are looking for accelerated 2D/3D or video decoding use Android** and do not bother with trying this image.
Important: I will not provide any further releases to the this Arch image. If you use this image, the Kernel and U-Boot update script will continue to work but you will not benefit from any packaging stuff i do for Ubuntu. Consider to change to my Ubuntu 16.04 Xenial Xerus releases.
What you get:
- HDMI at 1080p with 60Hz
- Ethernet (100M only including 1000M)
- USB
- Wifi
- Arch Linux aarch64
- BSP Linux Kernel 3.10.65+ (see http://forum.pine64.org/showthread.php?tid=293)
- BSP U-Boot (see http://forum.pine64.org/showthread.php?tid=99)
- Support for all Pine64 models (512MB, 1GB, 2GB) with auto detection so Ethernet works with the same image on all models
It actually works good enough so i feel i can publish it.  While the image is quite minimal, you can install all the software from the Arch Linux aarch64 repository including X11 and Xfce.
Screenshots
Download (for instructions see README.txt)
History:
**20160221-2**
- Initial public release
- Known issue: Ethernet hardcoded to use 100M only
- Known issue: Firefox crashes
- Known issue: Audio does not work (Inappropriate ioctl for device)
- Known issue: Kernel is entered in EL1
**20160227-1**
- Ethernet now supports 1000M
- Kernel is now entered in EL2, means the hypervisor works (tested with KVM)
- Disk size was reduced to 3700MiB so it fits on 4GB media
**20160304-1**
- Kernel updated to 20160304-1.
- Device tree was updated to improve thermal throttling and Ethernet 1000M speed and compatibility.
**20160308-1**
- Updated U-Boot and device tree to 20160306-1
- Updated Kernel to 3.10.65-2-pine64-longsleep-39-1
- Ethernet MAC address is now persistent (added to uEnv.txt on first boot)
- Added system service to reenable CPU cores
- Added helper Pine64 platform scripts to /usr/local/sbin
- Linux Kernel firmware and headers are now installed
**20160403-1**
- Updated Kernel to 3.10.65-4-pine64-longsleep-16 (fixing Pine64+ 2GB model Ethernet crash)
Released images are signed with a detached GPG signature (.asc) signed by my personal key 0x090EF0DB. Get the key and verify that the download is intact and unmodified.
gpg --keyserver keyserver.ubuntu.com --recv-keys 090EF0DB
gpg --with-fingerprint arch-pine64-*.xz.asc
Let me know what you think.
Arch Linux image (BSP Kernel) - by longsleep - 02-21-2016, 11:17 AM
RE: Arch Linux image (BSP Kernel) - by tllim - 02-21-2016, 09:21 PM
RE: Arch Linux image (BSP Kernel) - by janjwerner - 02-21-2016, 09:56 PM
RE: Arch Linux image (BSP Kernel) - by longsleep - 02-27-2016, 07:07 AM
RE: Arch Linux image (BSP Kernel) - by tllim - 02-22-2016, 10:48 PM
RE: Arch Linux image (BSP Kernel) - by janjwerner - 02-23-2016, 08:11 AM
RE: Arch Linux image (BSP Kernel) - by longsleep - 02-27-2016, 11:16 AM
RE: Arch Linux image (BSP Kernel) - by coleshores - 02-27-2016, 11:52 AM
RE: Arch Linux image (BSP Kernel) - by janjwerner - 02-27-2016, 12:52 PM
RE: Arch Linux image (BSP Kernel) - by KC7NOA - 02-27-2016, 01:02 PM
RE: Arch Linux image (BSP Kernel) - by T3charmy - 03-03-2016, 08:48 AM
RE: Arch Linux image (BSP Kernel) - by longsleep - 03-05-2016, 04:08 AM
RE: Arch Linux image (BSP Kernel) - by Ghost - 03-05-2016, 09:26 AM
RE: Arch Linux image (BSP Kernel) - by longsleep - 03-05-2016, 11:08 AM
RE: Arch Linux image (BSP Kernel) - by Ghost - 03-05-2016, 11:51 AM
RE: Arch Linux image (BSP Kernel) - by tllim - 03-05-2016, 01:20 PM
RE: Arch Linux image (BSP Kernel) - by janjwerner - 03-05-2016, 09:46 AM
RE: Arch Linux image (BSP Kernel) - by Ghost - 03-05-2016, 11:06 AM
RE: Arch Linux image (BSP Kernel) - by longsleep - 03-05-2016, 01:38 PM
RE: Arch Linux image (BSP Kernel) - by norm24 - 03-05-2016, 05:52 PM
RE: Arch Linux image (BSP Kernel) - by longsleep - 03-10-2016, 02:28 PM
RE: Arch Linux image (BSP Kernel) - by duanhongyi - 03-10-2016, 08:15 PM
RE: Arch Linux image (BSP Kernel) - by Artyom - 03-20-2016, 10:16 AM
RE: Arch Linux image (BSP Kernel) - by longsleep - 04-03-2016, 09:05 AM
RE: Arch Linux image (BSP Kernel) - by piney - 04-07-2016, 06:21 PM
RE: Arch Linux image (BSP Kernel) - by longsleep - 05-06-2016, 02:24 PM
RE: Arch Linux image (BSP Kernel) - by tllim - 05-06-2016, 06:33 PM
  eMMC doesn't work after kernel start m.bakhterev 3 5,998 10-15-2019, 10:58 AM
Last Post: m.bakhterev
  what/where is the package manager on Arch Linux? spruce1 9 12,126 04-03-2019, 05:58 AM
Last Post: jose.ramirez
  Arch Linux mainline XFCE pineadmin 12 34,206 02-21-2019, 05:52 AM
Last Post: starcrescent
  No CIFS support in Kernel? jamespo 4 9,289 06-28-2016, 01:28 PM
Last Post: jamespo
Question Arch Killing long running node/npm processes before finishing faddah 4 7,230 04-28-2016, 08:53 PM
Last Post: patrickhwood
  using dd to clone image jproffer 2 6,065 04-27-2016, 07:49 PM
Last Post: jproffer
