corrupt microsd card after reboot
(02-06-2017, 02:12 PM)maxpayne Wrote:
(02-06-2017, 01:32 PM)Ghost Wrote: Not sure if it is microSD related, but have you tried a different card to eliminate that possibility?
Nope, I was hopping to get more clues on the issue before buying another card Confused
Buying another microSD to test seems like a relatively cheap way of finding out whether the card is at fault or not.
How are you shutting down the Pine? Via the software menu activated by a short press of the power button, or just by pulling out the power cord?
Incorrect shutdown procedure can lead to a card getting corrupted. MicroSD cards are very susceptible to this.
The card also needs to have good random read/write speeds. Many cards, even modern ones, are only good at linear reads and writes. This is fine for simply uploading and downloading media to and from the card, but running an operating system requires more complexity than this and so needs to be efficient when it comes to random read/write performance. Some cards just can't handle it.
corrupt microsd card after reboot - by maxpayne - 02-06-2017, 12:24 PM
RE: corrupt microsd card after reboot - by Ghost - 02-06-2017, 01:32 PM
RE: corrupt microsd card after reboot - by Ghost - 02-06-2017, 05:09 PM
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,690 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,048 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,454 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,363 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,453 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 212,465 03-03-2020, 11:34 PM
Last Post: siyatalerja
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 150,391 01-15-2020, 12:46 PM
  PSCI, u-boot and reboot on Sopine ClusterBoard hbaxmann 0 2,328 09-03-2019, 11:57 PM
Last Post: hbaxmann
  eMMC card on adapter Malmgren 8 11,184 03-20-2018, 11:14 AM
Last Post: Malmgren
  recommended micro sd card? Gustavo Woltmann 1 3,593 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
