Playbox battery charge
(12-06-2016, 12:26 PM)Jessica Spongekipper Wrote: OK. Sadly I have a similar problem. I have a 8000 mah 2 wire cell, but. I have had the plug in a socket on the bench and I have volts at 1 & 3 and 9.98k ohms between 2 and gnd. I have charge but according to the script taken from these august pages, only 2ma @ v volts. Any clues as to what I may have done wrong ?
At what voltage? Once the battery is fully, the (charge) current will drop to 2ma... i.e. my battery is sat at 4.18v, and is fully charged, with a 2ma charge current (although I doubt it is really 2ma... but is in fact 0ma at that point and the 2ma is just a accuracy error... I haven't bothered measuring the output from the PMIC to see how accurate it is yet).
Try this script if you're  not getting charge state / current / voltage / capacity readings. Note it needs bc to display the voltage  (sudo apt-get install bc)... one of these days I'll get around to either removing that dependency or adding a check for it...  Wink
You'll be able to load it directly onto the pine64 if it has internet access with the following command:
wget https://gist.githubusercontent.com/pfeerick/05e5715733f00dcf303636c80abff598/raw/9bfca4be89ed219658426701b702a2663329f2df/pine64-battery.sh
Don't forget to do a chmod +x pine64-battery.sh afterwards to make it executable!
Playbox battery charge - by jdmwrx94 - 10-20-2016, 07:42 PM
RE: Playbox battery charge - by Bluphire - 10-20-2016, 10:32 PM
RE: Playbox battery charge - by jdmwrx94 - 10-21-2016, 05:13 AM
RE: Playbox battery charge - by MarkHaysHarris777 - 10-21-2016, 05:44 AM
RE: Playbox battery charge - by jdmwrx94 - 10-23-2016, 07:41 AM
RE: Playbox battery charge - by pfeerick - 10-23-2016, 11:01 PM
RE: Playbox battery charge - by Pineplayer - 10-28-2016, 11:13 AM
RE: Playbox battery charge - by PakenPine - 10-31-2016, 01:42 PM
RE: Playbox battery charge - by pfeerick - 10-31-2016, 06:30 PM
RE: Playbox battery charge - by pfeerick - 12-06-2016, 07:49 PM
RE: Playbox battery charge - by Toriless - 12-20-2016, 07:19 AM
  Playbox with DAC llungster 0 2,721 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 12,244 02-22-2019, 03:24 AM
Last Post: GaryFunk
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 10,101 07-16-2017, 01:51 AM
Last Post: selina3
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,414 06-17-2017, 01:29 AM
Last Post: pfeerick
  playbox and camera jpfaubert 1 3,790 03-07-2017, 12:51 AM
Last Post: MarkHaysHarris777
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,667 02-12-2017, 10:17 PM
  Playbox case orderable? schindlb 8 13,555 10-02-2016, 08:20 AM
Last Post: schindlb
  Solution to awkward playbox cabling Visionrx7 2 4,247 09-13-2016, 11:46 PM
Last Post: Visionrx7
  Question regarding Playbox case jeffrey_ring 3 5,301 09-13-2016, 07:39 PM
  ABS Playbox came with no extension cable? kenhawkins 4 6,246 09-12-2016, 02:47 PM
Last Post: echild
