android image & sd card size problems
I ran into the same problem that others reported. I bought a Sandisk 32 GP microSD card, ran the H2testw program to check for errors.
test of microSD card
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 19.8 MByte/s
Reading speed: 78.2 MByte/s
H2testw v1.4
deleted the *.h2w files.
Windows explorer reports 131,027 bytes used space and 31,902,400,512 bytes free space. Win32diskmager.exe says there is not enough space for the file: android-ver5.1.1-20160711-pine64-32GB.img
Question: should I try with the image for a 16 GB card?
Tom Arneson
android image & sd card size problems - by tomarneson - 10-12-2016, 10:43 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,018 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,631 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,798 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,979 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,047 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,607 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,337 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 257,693 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,546 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,127 02-10-2019, 07:44 PM
Last Post: mmmarcus
