Dmesg output Ubuntu Mate
Came across this log today and thought I would post it on the list. This is not complete but shows some of the output being generated by Cedar and Mali. Like others I look forward a full support for the graphics drivers - but some progress evident.
Ubuntu 3.10.101-4-pine64-longsleep
19.103654] sunxi cedar version 0.1
[   19.103800] [cedar]: install start!!!
[   19.103884] ycy the get irq is 90
[   19.104155] ycy clk_bass_vir 0x18  is ffffff80013da018, the value:3006207
[   19.104160] ycy clk_bass_vir 0x13c  is ffffff80013da13c, the value:0
[   19.104165] ycy clk_bass_vir 0x64  is ffffff80013da064, the value:601810
[   19.104170] ycy clk_bass_vir 0x2c4  is ffffff80013da2c4, the value:601c10
[   19.104174] ycy clk_bass_vir 0x100  is ffffff80013da100, the value:0
[   19.104177] [cedar]: install end!!!
[   19.300342] Mali: Set gpu frequency to 408 MHz
[   19.300396] Mali: Init Mali gpu clocks successfully
[   19.300513] gpu cooling callback register Success
[   19.303814] Mali: Mali device driver loaded
[   19.358904] cfg80211: World regulatory domain updated:
[   19.358923] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   19.358929] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   19.358934] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   19.358939] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   19.358944] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   19.358949] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   19.358954] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   19.358959] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   19.358964] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   19.508460] [VFE]Welcome to Video Front End driver
[   19.508732] [VFE]csi probe end csi_sel = 0!
[   19.509174] [VFE]csi_init end
[   19.510483] [VFE]isp probe start isp_sel = 0!
[   19.511286] [ISP] isp platform_id = 3!
[   19.511298] [VFE]isp probe end isp_sel = 0!
[   19.511348] [VFE]sunxi_isp_platform_register end
[   19.511680] [VFE]mipi probe start mipi_sel = 0!
[   19.511694] [VFE]mipi probe end mipi_sel = 0!
[   19.511724] [VFE]mipi_init end
[   19.512594] [VFE]flash_init end
[   19.513469] [VFE]pdev->id = 0
[   19.513476] [VFE]dev->vip_sel = 0
[   19.513497] [VFE_WARN]fetch csi0_dev0_twi_id from device_tree failed
[   19.513529] [VFE_WARN]fetch csi0_dev0_afvdd from device_tree failed
[   19.513536] [VFE_WARN]fetch csi0_dev0_afvdd_vol from device_tree failed
[   19.513545] [VFE_WARN]fetch csi0_dev0_power_en from device_tree failed
[   19.513575] [VFE_WARN]fetch csi0_dev0_flash_en from device_tree failed
[   19.513582] [VFE_WARN]fetch csi0_dev0_flash_mode from device_tree failed
[   19.513594] [VFE_WARN]fetch csi0_dev0_af_pwdn from device_tree failed
[   19.513614] [VFE_WARN]fetch csi0_dev1_twi_id from device_tree failed
[   19.513641] [VFE_WARN]fetch csi0_dev1_afvdd from device_tree failed
[   19.513647] [VFE_WARN]fetch csi0_dev1_afvdd_vol from device_tree failed
[   19.513654] [VFE_WARN]fetch csi0_dev1_power_en from device_tree failed
[   19.513676] [VFE_WARN]fetch csi0_dev1_flash_en from device_tree failed
[   19.513683] [VFE_WARN]fetch csi0_dev1_flash_mode from device_tree failed
[   19.513695] [VFE_WARN]fetch csi0_dev1_af_pwdn from device_tree failed
[   19.513712] [VFE]fetch rear sensor list info start!
[   19.513717] [VFE]Fetch sensor list form"/system/etc/hawkview/sensor_list_cfg.ini"
[   19.550162] [vfe_warn]open file failed!
[   19.588247] [VFE]fetch rear sensor list info end!
[   19.588301] [VFE]fetch front sensor list info start!
[   19.588307] [VFE]Fetch sensor list form"/system/etc/hawkview/sensor_list_cfg.ini"
[   19.624396] [vfe_warn]open file failed!
[   19.662379] [VFE]fetch front sensor list info end!
[   19.662589] [VFE_WARN]os_gpio_request failed, gpio=129, ret=0xfffffff0, -16
[   19.662810] [VFE]vfe_init end
[   19.666063] [VFE]probe_work_handle start!
[   19.666200] [VFE]vfe_runtime_resume
[   19.678281] [VFE]..........................vfe clk open!.......................
[   19.678295] [VFE_WARN]vfe dphy clock is null
[   19.678318] [VFE]v4l2 subdev register input_num = 0
[   19.678471] [VFE]vfe sensor detect start! input_num = 0
[   19.678481] [VFE_WARN]NOT found this item:  hm5065, you can add this sensor in the sensor_list_t!
[   19.678487] [VFE]Sub device register "hm5065" i2c_addr = 0x3e start!
[   19.678492] [VFE_ERR]Error registering v4l2 subdevice No such device!
[   19.693824] [VFE_ERR]vfe sensor register check error at input_num = 0
[   19.707085] [VFE]v4l2 subdev register input_num = 1
Dmesg output Ubuntu Mate - by S265 - 10-01-2016, 09:42 PM
  Issues with both Deb and Ubuntu germanshep 0 2,526 08-28-2018, 05:47 PM
Last Post: germanshep
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 9,996 11-02-2017, 06:34 AM
Last Post: XaRz
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 10,084 03-01-2017, 02:46 PM
Last Post: dkryder
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 5,016 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 6,381 10-03-2016, 04:23 AM
Last Post: Shai
  Overclocking ubuntu mate Mixermic 2 4,956 10-01-2016, 04:36 AM
Last Post: pfeerick
  How to make multicast working on ubuntu and debian brengthdom 3 7,020 09-18-2016, 02:05 PM
Last Post: brengthdom
  Camera support - Ubuntu Xenial 16.04 LTS @lex 3 5,214 08-07-2016, 03:47 AM
Last Post: romansavrulin
  [How-To] Make PINE 64 with Ubuntu Xenial Longsleep build crunch BOINC Tasks moisesmcardona 3 8,073 07-27-2016, 01:16 PM
Last Post: NexusDude
  Kodi on pine 2gb/ubuntu os very very slow? ktaragorn 7 10,457 07-19-2016, 08:57 PM
Last Post: lenny.raposo-pine64.pro
