Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO*
    I ordered one of these and see that with some small modifications, it can be turned into a very sleek, standing case.
I'm dropping the corner brackets, which are only needed to protect the screen if the unit is used as a playbox. Mine will be standing permanently in my HiFi shelves in picture-frame posture.
That brings me to my question or request.
If anyone knows of a source of some flat aluminium brackets, about 3mm thick, 1-2cm wide and bent at a 65°/115° angle, that could be cut to length and polished, I'd be happy to know about them. I don't care what they're originally intended for.  One end will be bolted to sides of the back of the C4 enclosure, while the other will sit on the shelf, supporting the unit at a nice, 65°(ish) angle.
Of course I can manufacture them myself if necessary, but bending two, exactly matched angles from flat aluminium may be difficult.
Cheers!
--Marius--
angled feet - by Learnincurve - 01-06-2017, 03:15 AM
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 164,119 11-02-2020, 08:43 PM
Last Post: Little_Johnny
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,225 07-23-2020, 05:31 AM
Last Post: devendraraju
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,802 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 34,032 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,430 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,484 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,677 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 12,920 02-07-2017, 08:45 PM
Last Post: Bluphire
  Tablet Enclosure Vachtra 11 19,918 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 18,937 11-01-2016, 06:23 PM
