Battery Backup for media center.
HI,
I purchased a battery with my Pine64 2G through Kickstarter. It came with the connector to fit the Pine64 board and charges just fine through the micro USB connector. I think you can get this battery through the Pine64.org store.
I hope I did not misunderstand you question.
Edit: On checking the store I do not see the rechargeable battery offered. Not sure if it will be up later. I have seen several items that come and go so they may only list the items they have in stock.
I would send a question email to the Pine64.org store. Good luck
The Pine64 battery I got was 8,000ma.  This is a 10,000ma battery:
https://www.amazon.com/Lithium-Battery-T...7v+battery
I was unable to find the connector. (3pin PH type connector) Again, check with the pine64.org store.
(09-12-2016, 09:28 AM)Zone Wrote: Greetings everyone!
I've purchased Pine 64 specifically for a car media server is going to be built into glove compartment.
In order for my project comes to fruition the pine 64 needs a battery backup that via a script in once the car is turned off to gracefully shut down.
The battery needs to charge through micro USB. I'm looking for a product that is the quickest/simple plug-and-play setup that is safe to use. I've read quite a few threads but there's a lot of different opinions and setups. Thoughts and links to products?
Battery Backup for media center. - by Zone - 09-12-2016, 09:28 AM
RE: Battery Backup for media center. - by Sawadee - 09-12-2016, 03:40 PM
RE: Battery Backup for media center. - by Zone - 09-13-2016, 08:38 AM
  PineA64 battery in Germany (specifications or alternatives) burningkrome 0 3,132 12-02-2018, 04:10 AM
Last Post: burningkrome
  Lithion 3.7 volt PineA64 battery Model 9070120P MarkHaysHarris777 9 14,379 12-10-2016, 10:01 AM
Last Post: mcrognale
  RTC Backup Battery Holder CR-2032 Issues steveslim 11 25,887 09-08-2016, 07:02 AM
Last Post: MarkHaysHarris777
  Battery Power clackamas 3 7,280 06-13-2016, 02:18 PM
Last Post: clackamas
