LCD touch pad blank screen
(08-30-2016, 08:40 PM)Terra854 Wrote:
(08-30-2016, 07:38 PM)tanarri Wrote:
(08-30-2016, 05:28 PM)Ghost Wrote:
(08-30-2016, 05:01 PM)tanarri Wrote:
(08-30-2016, 04:07 PM)Ghost Wrote: It could be an image burning issue, have you tried to burn a DD image using one of the available methods, instead of a PhoenixCard image?
I have not. I am not 100% sure what the best method is for burning a non phoenix card image is.
There is no best method, though Win32DiskImager might be easiest. Download that here:
https://sourceforge.net/projects/win32di...e/download
Then try the 8GB image, just to see if it works:
http://files.pine64.org/os/android/andro...64-8GB.zip
I just want to make sure I did this right since the results are worse. With windiskimager select the device select the image and just click write?
Yes. And once the burning process is finished, you can insert the SD card into the Pine and start it up.
That's what I thought in both the 64mb and 8 mb cases the screen doesn't even turn on. Neither image is rooted.
LCD touch pad blank screen - by tanarri - 08-30-2016, 09:16 AM
RE: LCD touch pad blank screen - by Ghost - 08-30-2016, 02:36 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 02:54 PM
RE: LCD touch pad blank screen - by Ghost - 08-30-2016, 03:17 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 03:22 PM
RE: LCD touch pad blank screen - by Ghost - 08-30-2016, 04:07 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 05:01 PM
RE: LCD touch pad blank screen - by Ghost - 08-30-2016, 05:28 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 07:38 PM
RE: LCD touch pad blank screen - by Terra854 - 08-30-2016, 08:40 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 10:50 PM
RE: LCD touch pad blank screen - by JMBRauch - 09-14-2016, 03:32 PM
RE: LCD touch pad blank screen - by tanarri - 09-14-2016, 08:22 PM
RE: LCD touch pad blank screen - by Ghost - 09-14-2016, 09:41 PM
RE: LCD touch pad blank screen - by Arvin - 09-19-2016, 05:07 PM
RE: LCD touch pad blank screen - by Ghost - 09-21-2016, 01:25 AM
RE: LCD touch pad blank screen - by tkaiser - 09-21-2016, 01:35 AM
RE: LCD touch pad blank screen - by Ddorrer - 09-22-2016, 06:16 AM
RE: LCD touch pad blank screen - by Ghost - 09-22-2016, 06:34 AM
RE: LCD touch pad blank screen - by Ddorrer - 09-22-2016, 12:53 PM
RE: LCD touch pad blank screen - by Ghost - 09-22-2016, 01:20 PM
  Reformatting postmarket os with ubuntu touch mackdaddy67 6 8,409 09-11-2020, 12:41 AM
Last Post: SwordfishII
  7" LCD Touch Screen Panel IanJames 0 2,067 04-01-2020, 04:40 PM
Last Post: IanJames
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,750 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  Rock64 + 7" touch screen naviathan 2 5,035 09-28-2017, 09:01 AM
Last Post: naviathan
  7" Screen - Does it work with Debian abasel 1 3,897 07-26-2017, 05:44 AM
Last Post: pfeerick
  RESOLVED - LCD screen not working, HDMI does asuras 10 15,967 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI-VGA adapter. Blank screen. trumad 10 17,915 03-05-2017, 03:17 AM
Last Post: pfeerick
  Does ubuntu img support the touch screen kingsing2 4 7,451 01-29-2017, 02:41 PM
Last Post: greglarious
  Can't get past boot screen... (RESOLVED) codetheweb 13 23,745 01-19-2017, 08:43 AM
Last Post: Michaelrowe01
  How to open Playbox with screen installed? LAPine 3 5,062 12-03-2016, 05:17 PM
Last Post: LAPine
