remix os Phoenix CARD and Win32 Problem
(08-17-2016, 02:11 AM)Tomas Gomez Sierra Wrote: I do not know how to start my Pine64.
I followed these steps
3.) Write image to your sd card using Win32 Disk Imager (is not recorded )
Tomas,
To 'start' your pine, you should simply need to connect the power - i.e. plug in the microUSB lead into a suitable power source. This CANNOT be your computer USB port, it will not provide enough power. You need to use a 5v 2A(more than 2A is fine) power adapter with a micro usb connector (or a microusb lead if your adapter has a USB socket). When you connect the power, a red light should come on near the micro usb port on the pine64.
When you say it is not recorded, do you mean there is an error, or does Win32 Disk Imager take several minutes to write the image to the micro SD card? If you mean when you look at the microSD card with windows explorer, that there is nothing there or windows wants to format the drive (do not click yes!!!), then that is normal, as Windows won't know how to read the Android filesystem.
RE: remix os Phoenix CARD and Win32 Problem - by pfeerick - 08-17-2016, 02:30 AM
  New RockPro64 Power Up Problem enorbet2 7 4,781 10-28-2023, 12:08 PM
Last Post: dkebler
  dependency problem cerno 4 4,779 05-07-2021, 08:18 AM
Last Post: cerno
  How to boot from SD card on pinebook pro linux123 3 5,947 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,386 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,286 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,363 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 210,319 03-03-2020, 11:34 PM
Last Post: siyatalerja
  First Boot HDMI/USB problem reefer 1 4,937 11-18-2018, 10:32 PM
  ethernet lan speed problem android fulltone 0 2,593 04-23-2018, 01:47 AM
Last Post: fulltone
  eMMC card on adapter Malmgren 8 10,997 03-20-2018, 11:14 AM
Last Post: Malmgren
