Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation
(07-29-2017, 05:44 PM)MarkHaysHarris777 Wrote:
The pics above are a rework of the PI filter on my PineA64 desk board.  In this case the schematic has been modified to have two caps in parallel on either side of the inductor, which on this board was wound by hand.
The only change I would recommend is adding a couple "faster" ceramic capacitors given that electrolytic caps have high internal resistance (ESR value) and are considered "slow".
Also a flyback diode on the coil to protect against voltage spikes when unplugged.
RE: Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation - by evilpete - 12-19-2020, 09:53 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,103 07-03-2021, 01:29 AM
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,530 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,359 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,818 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,358 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,609 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,950 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,365 01-07-2017, 11:59 PM
Last Post: aegrotatio
  Correct Voltage For Powering From Euler?? thisrestricted 7 11,278 10-18-2016, 06:49 PM
Last Post: veronicasmithen03
  First cable for Euler Bus power done! AVL2016 24 33,181 10-05-2016, 06:43 AM
Last Post: Ghost
