A Tale of Two Power Supplies - why good is good and better is best
Nice writeup Mark... I'm sure that will help a lot of new users. Maybe you can make this a sticky topic for this thread?
btw, I think you meant  18-20 above where you were talking about wire gauge... not  18-25 (i.e.  A range of 18-20 AWG is satisfactory).
Also switching vs linear, you can usually tell by weight. Most of the adapters that could be considered linear are simply a transformer (and are usually much heaver than switching power supplies), which is why the voltage drops as they are loaded up, as there is actually no regulation. An good example is the earlier modem power supplies, almost all of them (in this country at least) were just a AC 240v to 9v AC transformer.... the regulation happened in the modem. However, this was nowhere as efficient as switching power supplies, and wasn't the best when you needed heavy currents. Plus the dodgier ones got warm and used a lot of power when they weren't doing anything.
RE: A Tale of Two Power Supplies - why good is good and better is best - by pfeerick - 08-10-2016, 12:19 AM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,074 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,483 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,521 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,316 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,725 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,319 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,414 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,912 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
  First cable for Euler Bus power done! AVL2016 24 33,031 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 6,780 10-02-2016, 04:35 AM
Last Post: pfeerick
