recommended micro sd card ?
#80
Just tested my USB Stick again, it's a 64GB Sony USB3.0 (dont know the exact model, PID is 0x054c, VID is 0x05b8) here are the results...
ubuntu@pine64:/mnt$ sudo  iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
       Iozone: Performance Test of File I/O
               Version $Revision: 3.429 $
               Compiled for 64 bit mode.
               Build: linux
       Run began: Sun Jun 19 01:08:52 2016
       Include fsync in write timing
       O_DIRECT feature enabled
       Auto Mode
       File size set to 102400 kB
       Record Size 4 kB
       Record Size 16 kB
       Record Size 512 kB
       Record Size 1024 kB
       Record Size 16384 kB
       Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
       Output is in kBytes/sec
       Time Resolution = 0.000001 seconds.
       Processor cache size set to 1024 kBytes.
       Processor cache line size set to 32 bytes.
       File stride size set to 17 * record size.
                                                             random    random     bkwd    record    stride
             kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
         102400       4     6827     5851    10475    10383     5126      196
         102400      16     7675     7773    21236    21252    14183      795
         102400     512    15876    11976    38357    38526    37429     5403
         102400    1024    11973    11278    39063    39085    38639     5687
         102400   16384    13439    10519    41124    41095    41127    12157
iozone test complete.
As you can see, read performance reaches twice the speed of my Samsung card (see above) for large record sizes but the random writes for small block sizes show really bad performance. I wonder if that is due to the ext4 filesystem I put on the stick...
recommended micro sd card ? - by mronhb - 01-24-2016, 06:10 PM
RE: recommended micro sd card ? - by Ghost - 01-24-2016, 07:29 PM
RE: recommended micro sd card ? - by mronhb - 01-24-2016, 09:44 PM
RE: recommended micro sd card ? - by fire219 - 01-25-2016, 09:14 PM
RE: recommended micro sd card ? - by mronhb - 01-26-2016, 05:00 PM
RE: recommended micro sd card ? - by Icon5585 - 01-27-2016, 09:37 AM
RE: recommended micro sd card ? - by Ghost - 01-27-2016, 09:51 AM
RE: recommended micro sd card ? - by SkimMilk - 01-28-2016, 06:04 PM
RE: recommended micro sd card ? - by tllim - 01-28-2016, 07:43 PM
RE: recommended micro sd card ? - by SkimMilk - 01-31-2016, 01:20 AM
RE: recommended micro sd card ? - by NoahJ - 03-02-2016, 05:42 PM
RE: recommended micro sd card ? - by benpope81 - 03-02-2016, 06:39 PM
RE: recommended micro sd card ? - by tllim - 03-02-2016, 10:58 PM
RE: recommended micro sd card ? - by benpope81 - 03-02-2016, 11:38 PM
RE: recommended micro sd card ? - by thtroyer - 03-15-2016, 04:43 PM
RE: recommended micro sd card ? - by SkimMilk - 03-17-2016, 09:19 AM
RE: recommended micro sd card ? - by tllim - 03-17-2016, 09:30 AM
RE: recommended micro sd card ? - by SkimMilk - 03-17-2016, 10:04 AM
RE: recommended micro sd card ? - by Kevydee - 04-11-2016, 03:22 PM
RE: recommended micro sd card ? - by Zoltrix - 03-18-2016, 05:59 AM
RE: recommended micro sd card ? - by Ghost - 03-18-2016, 06:02 AM
RE: recommended micro sd card ? - by Zoltrix - 03-18-2016, 06:15 AM
RE: recommended micro sd card ? - by tllim - 03-18-2016, 08:07 AM
RE: recommended micro sd card ? - by tllim - 03-18-2016, 12:39 PM
RE: recommended micro sd card ? - by nagmier - 03-18-2016, 04:47 PM
RE: recommended micro sd card ? - by tllim - 03-18-2016, 05:04 PM
RE: recommended micro sd card ? - by COMPUTIAC - 04-26-2016, 03:26 PM
RE: recommended micro sd card ? - by xrez - 04-27-2016, 08:20 PM
RE: recommended micro sd card ? - by hyperlogos - 04-28-2016, 07:21 AM
RE: recommended micro sd card ? - by androsch - 04-28-2016, 11:56 AM
RE: recommended micro sd card ? - by tkaiser - 04-28-2016, 12:01 PM
RE: recommended micro sd card ? - by androsch - 04-28-2016, 12:08 PM
RE: recommended micro sd card ? - by xrez - 04-29-2016, 02:51 AM
RE: recommended micro sd card ? - by Ghost - 04-29-2016, 03:24 AM
RE: recommended micro sd card ? - by tkaiser - 04-29-2016, 03:47 AM
RE: recommended micro sd card ? - by xrez - 04-29-2016, 07:45 AM
RE: recommended micro sd card ? - by tkaiser - 04-29-2016, 08:19 AM
RE: recommended micro sd card ? - by xrez - 04-29-2016, 08:40 PM
RE: recommended micro sd card ? - by tkaiser - 04-30-2016, 01:28 AM
RE: recommended micro sd card ? - by xrez - 04-30-2016, 03:18 AM
RE: recommended micro sd card ? - by tkaiser - 04-30-2016, 03:30 AM
RE: recommended micro sd card ? - by hyperlogos - 04-29-2016, 08:49 PM
RE: recommended micro sd card ? - by xrez - 04-30-2016, 02:55 AM
RE: recommended micro sd card ? - by tkaiser - 04-30-2016, 03:16 AM
RE: recommended micro sd card ? - by tkaiser - 05-01-2016, 03:39 AM
RE: recommended micro sd card ? - by hyperlogos - 05-01-2016, 01:09 AM
RE: recommended micro sd card ? - by hyperlogos - 05-02-2016, 06:34 AM
RE: recommended micro sd card ? - by tkaiser - 05-02-2016, 07:04 AM
RE: recommended micro sd card ? - by xrez - 05-02-2016, 01:02 AM
RE: recommended micro sd card ? - by tkaiser - 05-02-2016, 01:16 AM
RE: recommended micro sd card ? - by hyperlogos - 05-02-2016, 07:31 AM
RE: recommended micro sd card ? - by tkaiser - 05-02-2016, 08:00 AM
RE: recommended micro sd card ? - by hyperlogos - 05-05-2016, 05:42 PM
RE: recommended micro sd card ? - by tkaiser - 05-07-2016, 01:19 AM
RE: recommended micro sd card ? - by tllim - 05-07-2016, 11:41 AM
RE: recommended micro sd card ? - by benpope81 - 05-09-2016, 10:59 AM
RE: recommended micro sd card ? - by jl_678 - 05-11-2016, 03:15 PM
RE: recommended micro sd card ? - by Bob123456789 - 05-17-2016, 02:10 PM
RE: recommended micro sd card ? - by BeerSnob - 06-16-2016, 07:29 AM
RE: recommended micro sd card ? - by Bob123456789 - 06-16-2016, 08:18 AM
RE: recommended micro sd card ? - by BeerSnob - 06-16-2016, 08:35 AM
RE: recommended micro sd card ? - by Bob123456789 - 06-16-2016, 09:16 AM
RE: recommended micro sd card ? - by tllim - 06-16-2016, 12:22 PM
RE: recommended micro sd card ? - by Bob123456789 - 06-16-2016, 12:48 PM
RE: recommended micro sd card ? - by jl_678 - 06-16-2016, 05:50 PM
RE: recommended micro sd card ? - by Bob123456789 - 06-17-2016, 07:28 AM
RE: recommended micro sd card ? - by xalius - 06-18-2016, 05:25 AM
RE: recommended micro sd card ? - by Bob123456789 - 06-18-2016, 07:23 AM
RE: recommended micro sd card ? - by xalius - 06-18-2016, 08:19 AM
RE: recommended micro sd card ? - by Bob123456789 - 06-18-2016, 04:56 PM
RE: recommended micro sd card ? - by tllim - 06-18-2016, 05:00 PM
RE: recommended micro sd card ? - by xalius - 06-18-2016, 05:06 PM
RE: recommended micro sd card ? - by tllim - 06-18-2016, 05:11 PM
RE: recommended micro sd card ? - by xalius - 06-18-2016, 05:29 PM
RE: recommended micro sd card ? - by Bob123456789 - 06-18-2016, 05:50 PM
RE: recommended micro sd card ? - by jamesread90 - 07-01-2016, 03:24 PM
RE: recommended micro sd card ? - by Bob123456789 - 07-01-2016, 04:25 PM
RE: recommended micro sd card ? - by jamesread90 - 07-06-2016, 07:07 PM
RE: recommended micro sd card ? - by Bob123456789 - 07-07-2016, 09:14 AM
RE: recommended micro sd card ? - by xalius - 07-24-2016, 11:28 AM
RE: recommended micro sd card ? - by xalius - 06-17-2017, 11:19 AM
RE: recommended micro sd card ? - by S1ntax - 06-21-2017, 05:17 PM
RE: recommended micro sd card ? - by xalius - 06-23-2017, 10:37 AM
RE: recommended micro sd card ? - by Ron M - 02-05-2019, 03:12 PM
RE: recommended micro sd card ? - by wombat - 02-11-2019, 07:16 PM
RE: recommended micro sd card ? - by siyatalerja - 03-03-2020, 11:34 PM
  Recommended kits to buy? Silk 1 3,306 12-06-2020, 11:28 PM
  How to boot from SD card on pinebook pro linux123 3 6,084 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,475 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,379 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,469 03-18-2020, 09:42 AM
  eMMC card on adapter Malmgren 8 11,242 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 10,100 02-08-2017, 05:42 PM
Last Post: maxpayne
  unable to write an pine64 image on a 16G micro suresh 2 5,397 01-26-2017, 12:56 PM
Last Post: suresh
  recommended micro sd card? Gustavo Woltmann 1 3,619 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 3,687 11-03-2016, 02:33 PM
