[30/11/2016] pine64-config
Pine A64 Configuration Tool [30/11/2016]
This tool is based on the raspi-config tool for the Raspberry Pi and it provides a straight-forward way to configure your Pine64.
Source code is available at https://github.com/Terra854/pine64-config
Prerequisites
You will need to have the xterm package installed in order to use this tool. You will also need to install newt (for openSUSE) or whiptail (for Debian/Ubuntu).
Note that for openSUSE, the tool and it's dependencies has been preloaded in the images.
Downloads
Github link
Installation/Update the tool
To install or to update this tool for your Pine64, you will need to run the following command:
sudo ./install.sh [ubuntu/debian/opensuse]
This will build the scripts that is relevant to your distribution of Linux and installs it to /usr/local/sbin.
Once it is installed, you can execute it with:
sudo pine64-config.sh
Enjoy!
Changelog
25/7/2016
- Initial Release
26/7/2016
- Added Debian support
2/8/2016
- Minor bugfix
3/10/2016
- Lot's of bug fixes and improvements.
- openSUSE is now supported.
- Added the ability to change the cpu governor
- Added a heath monitor (looping the pine64_health script)
6/10/2016
- Major bugfixes
30/11/2016
- Fixed the cpu governor feature
If you want to contribute or to file bugs, please feel free to post an issue or open a pull request on the GitHub page.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
[30/11/2016] pine64-config - by Terra854 - 07-25-2016, 08:46 AM
RE: [BETA][25/7/2016] pine64-config - by Luke - 07-25-2016, 09:22 AM
RE: [BETA][26/7/2016] pine64-config - by tllim - 07-25-2016, 01:05 PM
RE: [BETA][26/7/2016] pine64-config - by Ophir - 07-29-2016, 10:43 AM
RE: [BETA][26/7/2016] pine64-config - by Terra854 - 07-31-2016, 02:22 AM
RE: [BETA][2/8/2016] pine64-config - by Bart333 - 08-18-2016, 03:05 PM
RE: [BETA][2/8/2016] pine64-config - by Terra854 - 08-24-2016, 10:46 AM
RE: [BETA][2/8/2016] pine64-config - by Terra854 - 10-02-2016, 08:48 AM
RE: [6/10/2016] pine64-config - by Terra854 - 10-06-2016, 06:49 AM
RE: [6/10/2016] pine64-config - by Terra854 - 11-30-2016, 08:15 AM
  Programming languages support under PINE64 baryluk 6 12,252 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 5,880 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 24,372 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,022 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 5,944 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 35,050 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,097 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,560 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 3,626 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 37,024 10-26-2017, 05:51 PM
Last Post: gregjo
