What OS have you recently flashed onto PBP eMMC?
We use the eMMC because it is faster. But if you want to evaluate different operating systems, you're better off (in my opinion) turning the eMMC off and just working with a pile of SD cards with different images.
Be careful writing to the SPI ROM. It is very hard to recover from trouble there.
To directly answer your question. NetBSD. It takes more patience to use it, but it's worth it to me. NetBSD pretty much does what I want it to do, not what someone else decided that I should want it to do.
I have two PBPs, one from early 2021 and one from the mid-2022 production run. Both of mine run NetBSD. I have (or had) a micro-SD card with "Debian Desktop", the pre-Manjaru default PBP OS, for when I need to do things that NetBSD won't easily do. But I can't remember the last time I needed it. I prefer that over Manjaru. My wife has an early PBP from the second production run, and it runs the latest Manjaru. It doesn't get updated. I update it maybe twice a year, and usually an update will brick it, and I get to sort that out. I expect that if it were updated regularly this wouldn't happen.
:wq
[ SRA accepts you ]
RE: What OS have you recently flashed onto PBP eMMC? - by KC9UDX - 11-26-2022, 09:39 AM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,048 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,484 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,240 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,707 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,163 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 2,018 01-17-2023, 12:07 PM
Last Post: nfms
  Unable to boot from emmc after flashing it rfm83 3 1,780 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 3,057 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 2,353 09-28-2022, 06:22 PM
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 214,784 09-27-2022, 07:41 AM
Last Post: olyavi
