keyboard charging fault, chip "most likely damaged", how to be sure?
The battery component of my pinephone keyboard is malfunctioning with symptoms described exactly in megi's FAQ, so I'm just quoting them here (emphasis mine):
Quote:Phone is not charging from the keyboard battery at all and keyboard power button does nothing
If
/sys/class/power_supply/ip5xxx-battery/uevent
does not become available, even when connecting the USB power supply to the keyboard, and is empty, that means that the charger chip is not responding, even when powered up. That means the chip is most likely damaged.
(source: https://xnux.eu/pinephone-keyboard/faq.html)
"most likely damaged", it says. Is there a known alternative possibility that I could test for, and possible ways to fix the unit?
I have had the keyboard for only a month and have barely used it. I was very aware that I should never charge it through the phone's USB-C socket and I am pretty sure I didn't. I did leave it connected to a charger via the keyboard's socket for a week once and maybe that's when the fault happened, although that still seems surprising to me.
keyboard charging fault, chip "most likely damaged", how to be sure? - by korakin - 10-01-2022, 07:39 AM
  keyboard case charging but not typing new2pinephone 18 5,613 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 7,700 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 411 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,091 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 438 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,206 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 503 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 604 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 992 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 805 10-11-2023, 09:03 AM
Last Post: elof
