After Flashing eMMC, Will Not Boot
OK, how do you know that a "generic" image is right for pbp?
Very likely the dtb is not right, the dtb is specific for different hardware
uboot is a very minimal bios, the dtb is much more specific
uboot only sets mem at a safe speed, initializes com, initialize (storage) media
and searches for config file, and then copy kernel, dtb, initrd to specific memory locations
and that's it
so,,, disable/remove emmc, do hard reset (20s press), try to boot SD
does it boot?
Use an image for pinebookpro, and MOST specificly NOT pinebook, this is completely different cpu
An easy mistake to make
After Flashing eMMC, Will Not Boot - by Mossbot - 09-27-2022, 06:37 AM
RE: After Flashing eMMC, Will Not Boot - by wdt - 09-28-2022, 12:29 AM
RE: After Flashing eMMC, Will Not Boot - by wdt - 09-28-2022, 06:22 PM
  uboot wont boot to SD card after upgrade jbradley419 7 804 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 286 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,215 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 686 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 584 11-22-2023, 11:47 AM
Last Post: fxc
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,130 11-20-2023, 06:22 PM
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,171 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,864 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 796 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,931 06-14-2023, 07:20 AM
