Broken usb-c to hdmi with kernel 5.18+
(10-01-2022, 04:42 PM)mjrr15 Wrote: Well, I risked the downgrade to 5.15 and broke the booting sequence. Found a way to recover though using an SD card with Armbian. Mounted EMMC /boot after booting Armbian.
Files in EMMC /boot were named *linux515* renamed to *linux* and copied vmlinuz-linux to Image (as I could not create a symbolic link). Then saw dtbs/rockchip/rk3399-pinebook-pro.dtb was missing so copied it from the Armbian /boot/dtb/rockchip folder (after creating the folder).
drwxr-xr-x  3 root root 8.0K Oct  1 17:18 dtbs
drwxr-xr-x  2 root root 8.0K Oct  1 17:05 extlinux
-rw-r--r--  1 root root 167K Jul 20 04:01 idbloader.img
-rw-r--r--  1 root root  30M Oct  1 17:05 Image
-rw-r--r--  1 root root  17M Oct  1 16:09 initramfs-linux-fallback.img
-rw-r--r--  1 root root 8.1M Oct  1 16:08 initramfs-linux.img
-rw-r--r--  1 root root   30 Sep 23 09:44 linux-aarch64.kver
-rw-r--r--  1 root root 978K Jul 20 04:01 u-boot.itb
-rw-r--r--  1 root root  30M Oct  1 16:08 vmlinuz-linux
All these details I found in the EMMC "/boot/extlinux/extlinux.conf" file:
LABEL Manjaro ARM
KERNEL /Image
FDT /dtbs/rockchip/rk3399-pinebook-pro.dtb
APPEND initrd=/initramfs-linux.img console=ttyS2,1500000 root=PARTUUID=1eeb7b54-686c-447f-80a7-b57c8d7b3345 rw rootwait audit=0 splash plymouth.ignore-serial-consoles
@mjrr15
Kernel 5.15 from Armbian has the same issue. Eventually I ended up installing TwisterOS and the image comes with kernel 5.10 so there is no HDMI issue there. Give it a try.
Now, it would be nice to find a Manjaro or Arch image that has these older kernel versions available.
Ideally this should be fixed though as it's such basic functionality and it has been broken for a long time.
Broken usb-c to hdmi with kernel 5.18+ - by rfm83 - 09-26-2022, 12:04 PM
RE: Broken usb-c to hdmi with kernel 5.18+ - by rfm83 - 10-02-2022, 01:33 PM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,759 01-22-2023, 10:05 PM
Last Post: rfm83
  minimal kernel .config? alchemist 5 5,921 08-15-2022, 06:28 PM
Last Post: svmhdvn
  Broken boot loader Tango Drango 4 2,422 08-15-2022, 11:38 AM
Last Post: Tango Drango
  No audio from HDMI with usb-c adapter rfm83 5 3,113 06-19-2022, 09:06 PM
Last Post: rfm83
Information Buying broken Pinebook Pro AtomC3 2 2,443 01-29-2022, 01:29 PM
Last Post: AtomC3
  Kernel panics on Youtube solostian 1 1,993 12-26-2021, 11:45 AM
Last Post: sirspate
  2021.10 u-boot broken on emmc clonex10100 3 3,537 12-14-2021, 04:24 PM
Last Post: jiyong
  Pinebook Pro - Display cable broken? snokis 0 1,516 08-17-2021, 11:30 AM
Last Post: snokis
  Broken Boot djhnsn 15 12,547 05-05-2021, 04:14 PM
Last Post: djhnsn
  Screen refresh delay with kernel errors shawnanastasio 31 38,667 04-27-2021, 02:57 AM
Last Post: james64
