Manjaro update: wxgtk dependency issue
(09-08-2022, 10:08 AM)KC9UDX Wrote: I don't know about "ver" but I expect "uname -a" should tell you about your operating system. (Though I can't be certain that this actually works in Manjaru.
Yeah, uname -a indeed responds with "5.7.19-1-MANJARO-ARM #1 SMP Wed Sep 2 20:43:09 +03 2020 aarch64 GNU/Linux
". I think I learned about the ver command back in the days and it has worked for me since, running SuSE linux and OpenSuSE. Things differ between distributions apparently. I also learned "acpi -V" doesn't quite work as expected. It tells me my battery has 0% remaining even though the icon in the plasma bar (whatever it is called) tells me it is at 38% currently. I'll try to update my command line skills, but I won't pollute this thread any further. As it is now, I hope it can be a useful resource for those running into this same upgrade issue. Either way, thanks all for your help![/color]
[/font]
Manjaro update: wxgtk dependency issue - by Vinay - 09-06-2022, 11:49 AM
RE: Manjaro update: wxgtk dependency issue - by Vinay - 09-09-2022, 12:03 PM
  Manjaro Sway Theme Broken Eighty8 1 262 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 305 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,722 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 309 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,081 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,163 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 389 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 861 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,998 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,949 08-21-2023, 09:08 PM
