128GB Card OS?
(07-12-2016, 11:31 AM)Ghost Wrote:
(07-12-2016, 08:09 AM)mesaxi Wrote: Has anyone gotten any OS to work with a 128GB microSD card? I attempted to flash the Remix OS to mine and it seemed to work, but got hung up on the Remix OS loading screen when I tried to boot it. When I was downloading the OS from the Pine wiki I noticed that there appear to be builds made for the various sized cards, but they top out at 64GB. I'm a total novice so there may be something I'm missing here, do I have to wait until there's a new build for the OS that's compatible with the 128GB card?
You should be able to put a 64GB image onto a 128GB microSD without issues. Problems would come from burning method used to burn the OS and also the integrity of the microSD card (i.e. whether it perhaps misreports its storage capacity).
I checked the card out and it's legit, I just may be doing this wrong. I got PhoenixCard and downloaded the Remix OS image at the bottom that says "Phoenix Card Image". Was that not the right one? The one above it is DD image for 64GB microSD card, should I use that one instead?
(07-12-2016, 12:27 PM)Tarjei85 Wrote: I'm running android ×0505 (rooted) on a 128gb card. Burned it with phoenix card.
Which image did you flash to your card?
128GB Card OS? - by mesaxi - 07-12-2016, 08:09 AM
RE: 128GB Card OS? - by Ghost - 07-12-2016, 11:31 AM
RE: 128GB Card OS? - by mesaxi - 07-12-2016, 12:32 PM
RE: 128GB Card OS? - by Ghost - 07-12-2016, 12:51 PM
RE: 128GB Card OS? - by Tarjei85 - 07-12-2016, 03:55 PM
RE: 128GB Card OS? - by Tarjei85 - 07-12-2016, 12:27 PM
RE: 128GB Card OS? - by mesaxi - 07-12-2016, 01:02 PM
RE: 128GB Card OS? - by Ghost - 07-12-2016, 01:37 PM
RE: 128GB Card OS? - by mesaxi - 07-12-2016, 01:47 PM
RE: 128GB Card OS? - by montero65 - 07-12-2016, 02:29 PM
RE: 128GB Card OS? - by mesaxi - 07-12-2016, 03:07 PM
RE: 128GB Card OS? - by mesaxi - 07-12-2016, 08:25 PM
RE: 128GB Card OS? - by Tarjei85 - 07-12-2016, 11:59 PM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,602 05-19-2023, 07:43 AM
Last Post: crocspot
Exclamation Can't boot when SD card inserted kivox 5 8,044 03-15-2020, 06:00 AM
Last Post: kivox
Photo Daughter Card SBC for P64 blue 5 7,053 08-22-2017, 07:51 AM
Last Post: blue
  Pine64 $15 card killed my $120 keyboard exa 22 27,635 01-04-2017, 09:01 AM
Last Post: skenn_ie
  overlapping partitions issue with resize of 8GB image put on 16GB sd card dkryder 10 12,086 10-05-2016, 11:32 AM
Last Post: dkryder
  SD card recovery TeaPack 8 8,704 08-07-2016, 07:35 AM
Last Post: xalius
  Can't write to SD card w/ Adapter apple4ever 2 4,289 07-23-2016, 03:16 PM
Last Post: apple4ever
  missing SD card xj-boonie 4 5,603 07-13-2016, 12:22 PM
  Problem making SD card Tam Dl 17 20,322 06-19-2016, 07:48 PM
Last Post: pfeerick
  Missing SD Card Chris_Mc11 0 1,782 04-26-2016, 06:02 PM
Last Post: Chris_Mc11
