Using multiple UART's on Rock64.
We are currently using UART on pins 8,10 for serial console. Based on the pin diagram, there are 2 more UART's available. One set on pins 15,18 and another set on pins 33,35 which is currently used for SD card slot. We are using Ayufan's Linux kernel release-4.4.167.
We are using EMMC and SD card slot is unused. So we want to disable it and use the UART functionality instead.
How can we configure these pins to be used as UART's. Is it possible to do with dtb overlay ? Is there any User guide or manual which could guide us with this configuration ?
Also what is the max baud rate that can be achieved on these UART's ? The one used for console port is 1500000 bauds.
Using multiple UART's on Rock64. - by ramprasad - 08-29-2022, 01:22 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 137 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,333 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 325 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 600 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 598 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,277 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,698 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 584 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 639 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,026 12-07-2022, 08:22 PM
Last Post: luminosity7
