How to upgrade Phosh on Pinephone?
WARNING This can cause problems.
These packages are on danctnix-testing server.
Update the phone as is:
sudo pacman -Syu
Restart the phone
sudo reboot
TURN ANIMATIONS ON
The animations can be turned on / off in the settings (Settings > Accessibility > Enable Animations).
add the danctix-testing to the pacman config
sudo nano /etc/pacman.conf
Add these lines to pacman.conf
[danctnix-testing]
Server = https://p64.arikawa-hi.me/danctnix-testing/aarch64/
Sync the pacman databases
sudo pacman -Sy
update only the phosh and phoc. Danctix has other package on the test server that you may not want right now.
sudo pacman -S phosh phoc
Restart the phone
sudo reboot
remove the danctix-testing to the pacman config
Remove these lines to pacman.conf
[danctnix-testing]
How to upgrade Phosh on Pinephone? - by ibid - 08-18-2022, 11:48 AM
RE: How to upgrade Phosh on Pinephone? - by mikehenson - 08-18-2022, 09:02 PM
  stuck between phosh and plasma aular 0 226 02-27-2024, 05:55 PM
Last Post: aular
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,241 01-14-2024, 08:43 AM
Last Post: shifras
  How to find software app, on Arch Phosh? general_lee 5 1,934 10-15-2023, 10:12 PM
  Evolution no longer runs on Arch Phosh. Chief 2 1,388 10-17-2022, 07:22 AM
Last Post: Chief
  Scaling problem Arch Linux Phosh Chief 7 3,175 09-27-2022, 12:31 PM
Last Post: Chief
  Delta Chat on Pinephone Emulti 1 1,527 07-31-2022, 07:32 AM
Last Post: magdesign
  repository for arch-phosh oihantto64 8 5,960 06-27-2022, 03:00 AM
Last Post: shulamy
  Customized Sway on Pinephone ragreenburg 2 2,074 05-22-2022, 12:20 PM
Last Post: ragreenburg
  Best Messaging client for pinephone? (arch-phosh) pineuser0 20 15,952 03-23-2022, 07:13 AM
Last Post: saba
  Arch image for Pinephone - where to get it? MikeMan 7 4,281 02-01-2022, 12:35 AM
Last Post: MikeMan
