KB: Using bus powered USB peripherals with the pinephone keyboard mounted
Yes - from the blog post linked above:
"To be fair, it is possible to turn the PPKB’s 5 V boost output off, both in software that talks to the battery charging IC inside the PPKB and by using the physical button on the PPKB itself, but it was concluded empirically that the inactive status of the charging part of the PPKB achieved that way simply cannot be trusted, because the charging part may become active again unexpectedly. Moreover, nothing gets electrically disconnected that way, which still ends up in a USB charger plugged into the phone’s USB port feeding power into the charging part of the PPKB, which in this case may be even worse for the health of the charging part, because there is now no power coming out of the PPKB to “fight against” the power coming in from the USB charger. Not good at all."
It seems to be a fundamental hardware problem that's going to need a redesign, unfortunately discovered after people had bought them.
RE: KB: Using bus powered USB peripherals with the pinephone keyboard mounted - by wibble - 06-30-2022, 01:44 AM
  keyboard case charging but not typing new2pinephone 18 5,223 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 5,648 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 525 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 360 11-26-2023, 07:24 AM
Last Post: eugenr
  Case for Pinephone totilele 12 6,526 11-04-2023, 09:43 AM
Last Post: Negome
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 7,906 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 394 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,114 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 449 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 562 10-21-2023, 02:55 AM
