RockPro64 premium aluminium casing
I'm considering ordering a RockPro64. There is an aluminium case for it that has a "Built-in heat pipe (plate) that directly contact[s] with SoC". Has anybody used one of these cases and does it provide adequate cooling?
If that is the case than I would probably first install Slackwarearm out of the case and then install the board in the case after the install. Would installing without a heat sink or heat sink with fan pose a risk of overheating and damaging the SoC?
RockPro64 premium aluminium casing - by justwantin - 05-27-2022, 12:34 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 1,941 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 889 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,687 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 842 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,614 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,588 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,147 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  Posible manufacturing problem with Premium Aluminum Casing. commiecam 0 931 09-09-2022, 10:47 AM
Last Post: commiecam
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,350 07-18-2022, 10:05 PM
Last Post: zer0sig
  charging 3 rockpro64 from single source rpt312 1 1,729 05-16-2022, 02:34 AM
Last Post: dukla2000
