Keyboard Case Redesign
This is my opinion. I own 2 original generation Pinephone v1.2b. I like the idea of the keyboard case, especially the addition of the battery. I waited on buying the keyboard case, as I didn't want to be a beta tester (I'm glad I waited). After witnessing the problems that others have experienced, I won't be purchasing the keyboard unless it is redesigned.
I think the Pinephone keyboard is a great accessory, but the POGO pin connection was a poor choice. I think it should be connected to the phone via USB and provide a USB hub.
Changing the Pinephone / Keyboard interconnection from POGO pins to USB has the following Pros & Cons:
Cons:
* A redesign of the keyboard's phone interface circuit would be required. (A USB circuit, and hopefull a hub so other USB devices could be attached)
* A redesign of the Pinephone mounting in the keyboard would be required.
* The keyboard battery level would have to be displayed on the keyboard itself.
Pros:
* No issues with poor contact with the POGO pins.
* Ability to use the Pinephone's USB port for peripherals (if a USB hub is added to the keyboard).
* No circuit redesign required of the Pinephone to prevent power feedback into keyboard if the phones USB port is used.
* The redesign of phone mount could allow for the back of the phone to remain in place including the LoRa and Fingerprint covers.
* The redesign of phone mount could allow for easier installation/removal of Pinephone from keyboard. (You could slide the phone out of the keyboard case to make/make a phone call - No spudger needed)
* No special keyboard driver to code and maintain.
Mark
Keyboard Case Redesign - by mark1250 - 05-25-2022, 01:37 PM
RE: Keyboard Case Redesign - by zetabeta - 05-26-2022, 08:27 PM
  Case for Pinephone totilele 13 6,995 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 277 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 5,614 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 7,706 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 411 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,091 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 438 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,206 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 503 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 604 10-21-2023, 02:55 AM
