Unable to install Debian Bullseye because of missing wifi firmware
I am trying to install Debian Bullseye. I have Tow-Boot already installed to SPI.
From http://http.us.debian.org/debian/dists/b...rd-images/ I downloaded 'partition.img,gz' and 'firmware.pinebook-pro-rk3399.img.gz' and combined them as per the accompanying README:
zcat ~/firmware.pinebook-pro-rk3399.img.gz ~/partition.img.gz > ~/complete_image.img
I then used Disk Image Writer to write the resulting image to SD.
The PBP/Tow-Boot boots the installer and I get to select Location, Language, Locale and Keyboard. The installer then probes the networking hardware and reports:
Quote:[!] Detect network hardware
Some of your hardware needs non-free firmware files to operate. The firmware can be loaded from removable media such as a USB stick or floppy. The missing firmware files are:
brcm/brcmfmac43456-sdio.pine64,pinebook-pro.bin
brcm/brcmfmac43456-sdio.bin
If you have such media available now, insert it, and continue.
Load missing firmware from removable media? [Yes/No]
I assumed this firmware would have been in the firmware image I used to create the installer.
I searched online but couldn't find these files.
On an SD card with Debian installed with Daniel Thompson's installer (unfortunately not longer working) I found 2 brcm directories with the following files:
BCM4345C5.hcd
brcmfmac43456-sdio.clm_blob
brcmfmac43456-sdio.txt
nvram_ap6256.txt
brcmfmac43456-sdio.pine64,pinebook-pro.txt
fw_bcm43456c5_ag.bin
Notably there is no 'brcmfmac43456-sdio.pine64,pinebook-pro.bin', but there is a .txt file with the same name.
I copied all these files to a USB thumb drive (EXT4). Running the installer again and answering 'Yes' to the 'Load missing firmware from removable media?' question only results in the installer repeating the question. Selecting 'No' gets me to a list of drivers to choose from but none of the Broadcom drivers selectable work.
What am I doing wrong?
Unable to install Debian Bullseye because of missing wifi firmware - by Pino64 - 05-12-2022, 06:28 AM
  Debian on Pinebook Pro u974615 7 849 03-31-2024, 10:11 AM
Last Post: u974615
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 314 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  install debian on pbp jsch 7 3,986 11-22-2023, 04:22 PM
Last Post: TRS-80
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 861 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,272 09-07-2023, 09:38 PM
  Install deepin OS on pinebook pro wangyukunshan 4 1,531 08-07-2023, 01:12 PM
Last Post: myself600
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,440 04-01-2023, 03:22 PM
Last Post: TRS-80
  Missing A Few Programs on PostmarketOS on PB Pro publiclewdness 0 542 03-06-2023, 11:33 PM
Last Post: publiclewdness
  unsuccessful re-install of OS for PineBookPro Valiance 3 1,279 02-14-2023, 12:49 PM
Last Post: Valiance
  5GHz wifi not working snorwood 11 5,492 01-16-2023, 03:41 PM
Last Post: ehcorn
