Unable to boot Armbian on new RockPro64
I'm new to Pine64 things.
I have new a RockPro64 4GB.
I flashed the appropriate Armbian using dd to my SD Card, I place it in the RockPro64, add HDMI monitor and power (using a non-official 5volts, 3A output supply), and the device doesn't boot.
U-Boot starts running, but we never make it to the actual booting process.
It hangs at:
"## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000".
I searched that message online and the only thing I found was a long since squashed bug.
At the very beginning of the boot process it says: "Warning - bad CRC, using default environment".
I tried to use the pine64-installer from github, but it won run for me, and there are multiple issues in the repo saying the same for other users.
The SD Card is not new, I used it for a year or so in an RPi with no problems.
Any pointers appreciated.
PS: i can't work out how to search on this forum, so I haven't searched for my issue here. Apols if it has already come up. I did look through the first boot threads though.
Unable to boot Armbian on new RockPro64 - by mooseball - 04-29-2022, 04:50 AM
  Installing Wifi drive for the RockPro64 John45595 0 291 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 9,322 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 118,965 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 743 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 656 09-08-2023, 08:14 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 672 08-14-2023, 07:55 AM
Last Post: kundanjha
  no boot white led flashing moserwi 7 4,278 05-18-2023, 10:46 AM
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 879 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,307 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,802 03-19-2023, 06:22 AM
Last Post: runyor
