Audio Pot Board Questions
(04-18-2022, 01:23 PM)vfr400racer Wrote:
(04-17-2022, 06:54 PM)t4_4t Wrote: > ... white 6 pin socket ...
It simply pulls out the signal as shown in the schematic.
Probably, it seems to be a terminal assuming the case of connecting another I2S-device (DAC etc...) to the outside.
> ... which pin is pin 1.
Look at the back of the board, there is a (50M / MCLK) silk mark.
The part where 50M is printed is pin 1.
However, even if you select the MCLK side, it will not work properly in many cases.
This is because many kernels are not set to output MCLK to the outside.
You can find such a post by searching the forum thread here.
Many thanks, now it's clear to me.Currently, I'm running a volumio image on the rock64 and it let's me select the 50M side. Which is fine for me Big Grin .
Hi vfr400racer, I'm new to this and am building a music streamer and am trying to load volumio on the Rock64. I see you have an image running. I have a Rock64 V3 and have tried loading an image of both Volumio V2 and V3 with no success, I can load other OS's such as DietPi for Rock64 but the Volumio ones from this forum seem to flash ok but dont load - no red/white led activity even after 30 mins or so and no display. Just wondering if you had any suggestions.
Audio Pot Board Questions - by vfr400racer - 04-17-2022, 01:51 PM
RE: Audio Pot Board Questions - by t4_4t - 04-17-2022, 06:54 PM
RE: Audio Pot Board Questions - by vfr400racer - 04-18-2022, 01:23 PM
RE: Audio Pot Board Questions - by Roberto2020 - 08-11-2022, 06:34 PM
RE: Audio Pot Board Questions - by Roberto2020 - 10-11-2022, 09:21 PM
  Rock64 4K60P HDR Media Board Computer 64 bit MarkHaysHarris777 8 13,921 07-14-2021, 11:52 PM
Last Post: jontumontu
  Help connecting a dvb board in the right gpio pins cosmodeal 0 1,685 11-11-2020, 12:48 PM
Last Post: cosmodeal
  Rock64 stereo audio dac add-on board with RockPro64 Tim13 1 2,805 07-08-2019, 07:15 PM
  Rock64 Stereo Audio DAC add-on board Hukmut 3 4,413 06-15-2019, 07:56 AM
Last Post: MiiCode2
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 4,456 01-09-2019, 01:02 AM
Last Post: t4_4t
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 2,831 12-01-2018, 03:53 AM
Last Post: jovval
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD angelscream09 7 6,444 11-21-2018, 07:02 PM
Last Post: antonv
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD Sketch killor 4 5,191 11-12-2018, 07:37 AM
Last Post: killor
  ROCK 64 board unresponsive S265 1 2,026 08-05-2018, 06:51 AM
Last Post: paradise
Lightbulb Looking for donor board to replace voltage regulator or any other ideas? ansic 1 2,213 04-15-2018, 09:15 PM
