Kernel OOPs triggered by big writes to ext4 FS
I've managed to avoid mounting filesystems in "sync" mode to stop Oops happening during heavy i/o by setting the Linux kernel "overcommit_memory" mode to never overcommit:
echo 2 > /proc/sys/vm/overcommit_memory
Also, to do it on boot:
echo "vm.overcommit_memory=2" >> /etc/sysctl.conf
I now have OMV6 working under Armbian 21.08.1 Bullseye with Linux 5.15.25-rockchip64 with u-boot in SPI, root on eMMC and dual 1TB SATA disks on an Adaptec AAR-1220SA controller. It's been a bit of an uphill struggle to get a working system. Most of the images I've tried have failed in the same way on ext4, Btrfs or ZFS - I think the overcommit occurs in the filesystem-independant kernel VFS. The system was quite stable under FreeBSD with root on eMMC, but my Adaptec controller is not supported so I couldn't test it. I want to run OMV6 under Armbian Bullseye, but tested my Rockpro64 under FreeBSD to see if the problem only occurs under Linux. What I find very puzzling is that I've not had the same Oops under heavy i/o on my Pinebook Pro, which is very similar hardware to the Rockpro64.
RE: Kernel OOPs triggered by big writes to ext4 FS - by ajtravis - 04-04-2022, 05:29 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 826 09-22-2023, 04:27 AM
Last Post: diederik
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 1,109 06-16-2023, 10:54 AM
Last Post: CounterPillow
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 1,831 05-08-2022, 03:26 PM
Last Post: paralin1
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 2,287 09-11-2021, 08:58 PM
Last Post: t4_4t
  compiling a new kernel for overclocking on arch Mentaluproar 2 2,758 07-15-2021, 10:16 AM
Last Post: Mentaluproar
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 3,007 07-14-2021, 02:37 PM
Last Post: TRS-80
  ayufan kernel update unbootable TheHunter 2 3,162 03-12-2021, 05:17 PM
Last Post: LMM
  Kernel oops after big-ish writes gaeb 1 2,343 02-11-2021, 03:55 PM
Last Post: gaeb
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 5,347 10-22-2020, 01:12 PM
Last Post: dukla2000
  Problem with compiling ayufans linux kernel voegelit 4 5,925 01-14-2020, 07:38 AM
Last Post: patstew
