Fresh Manjaro does not boot from eMMC
I put Tow-boot on the SPI. Then I flashed Manjaro-ARM-gnome-pbpro-22.02.img to a SD card, booted from it and used the manjaro-arm-installer to put Manjaro on my eMMC. I selected the minimal version with FDE. The installer finishes and I turned of the PBP. I removed the SD card and turned it on again. Tow-boot showed up and I pressed ESC to select to boot from eMMC (I guess this is not required since the eMMC is higher up in the boot order than the SD). Booting however fails each time and gives the errors that are visible in the following image: https://imgur.com/Wek8KNw
Did this happen to anyone else? I tried multiple times now with tow-boot and u-boot. I tried with the minimal and gnome versions with and without FDE. Can somebody help please?
Fresh Manjaro does not boot from eMMC - by pentamassiv - 03-22-2022, 06:59 PM
  Manjaro Sway Theme Broken Eighty8 1 261 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,721 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 307 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,080 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,161 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 388 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,177 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 860 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,998 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,948 08-21-2023, 09:08 PM
