Waydroid on PinePhone Pro PPP (Stock Manjaro Plasma)
(04-07-2022, 02:11 PM)m0n.t3 Wrote:
(02-15-2022, 06:32 PM)TheBlindEarthican Wrote: I found a case where they disabled the hardware render to get waydroid to start on the Pro.
#!/bin/bash
# Download image, can be slow
sudo waydroid init
# Older android images cant use hardware acceleration on new hardware, so turn off.
( sudo echo "ro.hardware.gralloc=default" ; sudo echo "ro.hardware.egl=swiftshader" ) >>/var/lib/waydroid/waydroid_base.prop
sudo systemctl enable waydroid-container.service
sudo systemctl restart waydroid-container.service
Then for start script:
#!/bin/bash
waydroid session start &
waydroid show-full-ui &
There is no guarantee that it will work, but you can try.
Thanks for this suggestion. This got Waydroid running for me on Pinephone Pro running Arch ARM in Phosh. Does this mean the Pinephone Pro GPU is not supported by Wayland?
The GPU is support by wayland. From my understanding, the LineageOS version used isn't compatible with the RK3399 GPU currently. I haven't tried it lately and I am unsure whether or not it has been updated for it yet.
RE: Waydroid on PinePhone Pro PPP (Stock Manjaro Plasma) - by TheBlindEarthican - 04-25-2022, 11:27 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 10 1,703 4 hours ago
Last Post: mburns
  [WIP] KDE Plasma Mobile 6.0 Builds & Ports dorkydev 5 658 04-15-2024, 08:08 AM
Last Post: u-kidjp
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 45,039 02-13-2024, 02:54 PM
Last Post: fxc
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 826 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 960 11-23-2023, 08:39 AM
Last Post: mburns
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 647 11-09-2023, 07:39 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 699 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,711 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,358 09-10-2023, 03:19 AM
Last Post: fxc
  Manajaro Plasma 6 files break unstable updates, 6-30 mburns 5 1,594 07-20-2023, 11:19 AM
Last Post: mburns
