ROCKPro64 DOA
(12-04-2021, 05:59 AM)ajtravis Wrote: I've closed my support ticket now - Very disappointed about the lack of support from Pine64, but a friend of mine solved the problem for me. it would be nice if Pine64 made it clear that the only way to boot a new ROCKPro64 is using an SD-card and the SPI is not functional by default.
I get the feeling you're on your own now when it comes to the Rock series of boards. It really is a case use whatever Distro boots for you. When they do boot they are very stable. I've Armbian Buster running on one Rock64, Android 9 on another and LibreElec running on a RockPro64. All running 24/7 from an SD card and so far no problems. Once you're not hammering the SD card with multiple writes its a safe enough medium to use.
ROCKPro64 DOA - by ajtravis - 11-23-2021, 07:18 PM
RE: ROCKPro64 DOA - by Rocklobster - 11-30-2021, 12:41 PM
RE: ROCKPro64 DOA - by ajtravis - 11-30-2021, 01:02 PM
RE: ROCKPro64 DOA - by Rocklobster - 12-01-2021, 07:41 PM
RE: ROCKPro64 DOA - by ajtravis - 12-04-2021, 05:59 AM
RE: ROCKPro64 DOA - by Rocklobster - 12-04-2021, 09:48 AM
RE: ROCKPro64 DOA - by zer0sig - 07-18-2022, 10:35 PM
RE: ROCKPro64 DOA - by ajtravis - 07-19-2022, 02:45 AM
RE: ROCKPro64 DOA - by ajtravis - 11-08-2022, 03:40 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 1,945 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 891 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,713 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 845 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,615 11-18-2022, 10:20 AM
Last Post: colinmarc
  RockPro64 not booting up mvicha@gmail.com 0 1,148 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,359 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,153 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,731 05-16-2022, 02:34 AM
Last Post: dukla2000
  help or suggestions removing RockPro64 Playbox please? jahway603 2 2,369 03-22-2022, 12:17 PM
Last Post: jahway603
