ROCKPro64 DOA
(11-30-2021, 12:41 PM)Rocklobster Wrote: [...]
When you say your RockPro64 is DOA, when you apply power is there any activity at all. I'm using my board booting off Armbian Focal 5.10 kernel via an SD card. I've a beefy 12v 5a power supply attached, sourced elsewhere to avoid under voltage issues. Have you tried an alternative power supply just to rule that issue out. Keep the board as stripped down as possible before you attempt to boot it.
There was no activity at all when I wrote an eMMC image and tried to boot from it, but a friend managed to get it to boot Debian Buster from an SD card: I was expecting to see Uboot output from the UART on the serial lines, when booting from the eMMC but there was nothing. We are now trying to reflash the SPI to run Uboot from there. Seems it's not DOA after all, but it was not clear to me that I would have to boot from an SD card even if I had created an eMMC image. Seems that, by default, the ROCKPro64 will not boot from eMMC.
Thanks,
  Tony.
ROCKPro64 DOA - by ajtravis - 11-23-2021, 07:18 PM
RE: ROCKPro64 DOA - by Rocklobster - 11-30-2021, 12:41 PM
RE: ROCKPro64 DOA - by ajtravis - 11-30-2021, 01:02 PM
RE: ROCKPro64 DOA - by Rocklobster - 12-01-2021, 07:41 PM
RE: ROCKPro64 DOA - by ajtravis - 12-04-2021, 05:59 AM
RE: ROCKPro64 DOA - by Rocklobster - 12-04-2021, 09:48 AM
RE: ROCKPro64 DOA - by zer0sig - 07-18-2022, 10:35 PM
RE: ROCKPro64 DOA - by ajtravis - 07-19-2022, 02:45 AM
RE: ROCKPro64 DOA - by ajtravis - 11-08-2022, 03:40 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,049 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 909 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,869 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 856 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,640 11-18-2022, 10:20 AM
Last Post: colinmarc
  RockPro64 not booting up mvicha@gmail.com 0 1,158 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,423 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,176 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,751 05-16-2022, 02:34 AM
Last Post: dukla2000
  help or suggestions removing RockPro64 Playbox please? jahway603 2 2,396 03-22-2022, 12:17 PM
Last Post: jahway603
