11-08-2021, 01:56 PM
(11-08-2021, 01:06 PM)t4_4t Wrote: I have purchased multiple 'EMMCs' from the 'pine64 store' and there are at least three different brands mixed in.Sorry I should of mentioned in the first post , I haven't bought the emmc module yet , I didn't want to purchase one and it wouldnt work with the newer kernels .
(The time I purchased the cards is quite far apart.)
Of the cards I own, the one with the brand name 'FORESEE: NCard' is a buggy card and will not boot without special handling.
There have been several similar reports on this brand.
However, the same 'FORESEE' card with a different brand name works perfectly fine without any special operation.
Is the 'EMMC' card you own a buggy card or not ?
I think you need to check that first.
Your post is helpful though as I wasn't aware that pine64 had different brands of emmc with differing results. It might explain why some posts suggest it worked for them and some suggest it didn't .
Is there an options to use a non pine64 emmc module that works with the rockpro64?
