Audio / Touchscreen - 2 New Stupid Questions
If I attach the touchscreen - - - it sounds like I have a wide connector for the video itself, and a narrow ribbon for the touch controls...so...
1) Are these ribbons of sufficient length to work with the acrylic enclosure, or should I abandon that bit?  It's fine if not, as I think I'd have a clunky look just laying the screen on the acrylic enclosure.
1b) Are there / Can I use some kind of short (under 12") EXTENSION CABLES for either/both of these ribbons?
but more importantly...
2) Does the touchscreen have SPEAKERS that work with Android...if so I'm assuming that this is carried by the wide ribbon connector?  If I install the touchscreen Android build, will I have audio through the screen, or do I need to do some other connecting?
2b) Is there something I have to do in SOFTWARE to get audio to work (drivers, etc.)?
Thanks,
Audio / Touchscreen - 2 New Stupid Questions - by phloog - 06-26-2016, 09:06 AM
  Hello All! New user - 2 basic Quartz64 questions oldschool 2 931 12-14-2023, 12:06 AM
Last Post: oldschool
  Pre-purchase questions (and an apology/plead) mayorchief 0 2,278 08-23-2020, 11:30 PM
Last Post: mayorchief
  Pre-boot questions bkheath 5 8,319 04-30-2019, 08:33 AM
Last Post: bkheath
  Motherboard PCI-E questions Debbie 1 3,405 03-31-2019, 06:26 PM
Last Post: mknawabi
  questions SammiLeighTully 2 4,462 11-20-2018, 02:17 PM
Last Post: SammiLeighTully
  Multi Room Audio - Pine style mjgoode 4 8,671 09-19-2018, 10:30 AM
Last Post: mjgoode
Question Do I need a touchscreen to run Android? chrbar 3 5,149 08-08-2018, 10:55 PM
Last Post: chrbar
  Which command line only OS? For streaming audio zirconx 5 6,310 09-27-2016, 06:53 AM
Last Post: zirconx
  A little whinge Some simple questions I hope MobileFusion 3 5,965 09-22-2016, 07:29 AM
Last Post: MobileFusion
  Audio quality ctigs 3 5,735 08-13-2016, 10:58 PM
Last Post: MarkHaysHarris777
