"file too short" problem causing many sofware dependencies to fail
(10-27-2021, 02:34 AM)Danct12 Wrote: May I ask which storage device did you install the OS on? Since that sounds like a very bad SD card.
As for fixing the issue, you can try reinstalling all the packages as a last resort before doing a clean flash.
For jumpdrive while installing, I used a samsung micro SD card, but other than that, I'm not using an sd card - only the eMMC
RE: "file too short" problem causing many sofware dependencies to fail - by pineuser0 - 10-31-2021, 09:57 AM
  Scaling problem Arch Linux Phosh Chief 7 3,166 09-27-2022, 12:31 PM
Last Post: Chief
  How to install dependencies for Gajim? tk1107 13 9,504 03-13-2022, 11:10 PM
Last Post: tk1107
  audio services shut down after short time on arch-phosh pineuser0 3 2,618 01-22-2022, 01:14 PM
Last Post: elagost
  auto-brightness problem phone screen going to completely dim DonF22 6 9,160 05-11-2021, 07:00 PM
Last Post: Timothy_Ecc
