Just reflashed to latest mobian, it never asked for disk encryption?
(10-18-2021, 07:54 AM)wibble Wrote: To be more specific see the 'Disk encryption' and 'Encrypted /home partition' sections of:
https://wiki.mobian-project.org/doku.php...o:security
You probably used the installer image when you did it before, rather than the normal image. It is probably possible to convert an existing install to an encrypted one, but I suspect it'll be easier and more reliable to back up at least any user data then reinstall using the installer image and restore user data. I say this having looked at doing a similar conversion on an older linux laptop install - the conversion process was at best some "here's how I did it" pages rather than something properly documented, and if any of it wasn't quite right there was a chance future updates would fail in interesting ways.
Yes you're correct. Checking my current image, it seems I didn't download the "installer". I didn't know there was a difference.
I didn't restore any data yet, so I'll just reinstall using "mobian-installer-pinephone-phosh-20210516.img", instead of "mobian-pinephone-phosh-20210517.img".
I wonder how many others missed this difference. Tongue
RE: Just reflashed to latest mobian, it never asked for disk encryption? - by JuniperFury - 10-18-2021, 10:24 AM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,862 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 17,502 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,214 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No sound after Mobian upgrade arbocenc 1 752 11-28-2022, 11:02 AM
Last Post: arbocenc
Exclamation No wIfI after Mobian update crakabeats 3 2,096 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,320 09-24-2022, 08:01 AM
Last Post: dante404
  PinePhone running Mobian - Malware extraction? names_fold 1 1,618 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 2,066 01-17-2022, 02:18 AM
Last Post: bcnaz
  Assists for running Mobian my PinePhone gilwood 0 1,585 01-01-2022, 04:38 PM
Last Post: gilwood
  ? vpn or tor for mobian rvh 9 7,165 12-02-2021, 05:58 PM
Last Post: b7l3wui26r
