First cable for Euler Bus power done!
#21
(10-04-2016, 07:14 AM)dkryder Wrote: the atx power supply is a good bench power source. many small electronics shops have used units for 5 to 10 dollars [u.s.]
The trouble with atx power supplies is that they often have a substantial minimum current draw (can be as high as 3-5 amps) or they don't work properly. A fully loaded Pine board would be on the low side of that. The reason for this is that most atx power supplies are switching supplies capable of delivering 5.1 volts regulated at fifteen or more amps -- so they are optimized for the expected high current draw... a low current load like the Pine board may not be adequate to meet the minimum current specs of the atx supply. Most of the time folks that use atx supplies for bench supplies need to fabricate a minimum dummy load -- and of course that can be done in the case of the pine board too.
RE: First cable for Euler Bus power done! - by MarkHaysHarris777 - 10-04-2016, 08:35 AM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,009 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,237 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,478 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,179 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,412 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,244 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 28,873 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,823 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,085 01-07-2017, 11:59 PM
Last Post: aegrotatio
  Correct Voltage For Powering From Euler?? thisrestricted 7 11,109 10-18-2016, 06:49 PM
Last Post: veronicasmithen03
