Can't update or install software
I installed Arch Linux ARM on my Pinephone. When I go to the software store to update, it seems to know there are updates, but it won't install them. I tried the latest release of Phosh, the latest release of Plasma and the July release of Phosh and they all do basically the same thing. I copied the code I got from the latest version of Plasma for your reference:
$ sudo pacman -Syu
We trust you have received the usual lecture from the local System Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibilty.
[sudo] sqassword for alarm:
:: Sychronizing package databases...
pine64     790.0 B 2.00 B/s
pine64         9.0 KiB  18.4 KiB/s
00:00
plasma       789.0  B  2.00  B/s
plasma 16.0 KiB  31.8 KiB/s
00:01
phosh        4.8 KiB  15.0  B/s
phosh 18.3 KiB  35.0  KiB/s
00:01
danctnix        2.1 KiB  6.00  B/s
danctnix        29.4 KiB  52.2  KiB/s
error: failed retrieving file 'core.db' from mirror.archlinuxarm.org : Resolving timed out after 10001 milliseconds
error: failed retrieving file 'extra.db' from mirror.archlinuxarm.org : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'community.db' from mirror.archlinux.org : Resolving timed out after 10000 milliseconds
warning: too many errors from mirror.archlinuxarm.org, skipping for the remainder of this transaction
error: failed retrieving file 'alarm.db' from mirror.archlinuxarm.org : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'aur.db' from mirror.archlinuxarm.org : Connection time-out
error: failed to synchronize all databases (download library error)
[alarm@danctnix ~]$
On initial bootup, in the code that scrolls past I see some errors. I just reinstalled the latest release of Phosh and snapped a pic of the code:
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
[FAILED] Failed to activate swap /dev/zram0.
[DEPEND] Dependency failed for Swaps
[   13.148714] iio iio:device2: failed to read Who-Am-I register
[DEPEND] Dependency failed for Swaps.
gpg: key75880CB9A4EE6B8 marked as ultimately trusted
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg; revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/116F79C5F8AEFD B1EAF3EFB375880CB9A4EEE6B8.rev'
gpg: Done
Any idea what's going on or what I can do to fix it?
Can't update or install software - by P3TER - 09-23-2021, 08:17 PM
RE: Can't update or install software - by bcnaz - 09-23-2021, 11:31 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 01:51 AM
RE: Can't update or install software - by bcnaz - 09-24-2021, 08:46 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 09:38 PM
RE: Can't update or install software - by bcnaz - 09-24-2021, 09:48 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 10:00 PM
RE: Can't update or install software - by kqlnut - 09-25-2021, 03:05 AM
RE: Can't update or install software - by kqlnut - 09-23-2021, 11:50 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 04:09 AM
RE: Can't update or install software - by kqlnut - 09-24-2021, 10:30 AM
RE: Can't update or install software - by bcnaz - 09-23-2021, 11:56 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 02:10 PM
RE: Can't update or install software - by P3TER - 09-24-2021, 05:33 PM
RE: Can't update or install software - by kqlnut - 09-24-2021, 06:48 PM
RE: Can't update or install software - by bcnaz - 09-25-2021, 02:17 AM
RE: Can't update or install software - by P3TER - 09-25-2021, 04:03 AM
RE: Can't update or install software - by bcnaz - 09-25-2021, 12:40 PM
RE: Can't update or install software - by P3TER - 09-26-2021, 01:04 AM
RE: Can't update or install software - by bcnaz - 09-26-2021, 03:43 PM
RE: Can't update or install software - by P3TER - 09-26-2021, 05:14 PM
RE: Can't update or install software - by kqlnut - 09-27-2021, 02:19 AM
RE: Can't update or install software - by bcnaz - 11-23-2021, 07:16 PM
RE: Can't update or install software - by P3TER - 12-26-2021, 04:49 PM
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,249 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 780 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,942 10-15-2023, 10:12 PM
  PPKB certain keys not working after kernel update ragreenburg 20 12,944 06-11-2023, 03:19 AM
Last Post: lectrode
  unable to install applications dln949 5 1,528 06-08-2023, 08:38 PM
Last Post: Conjada
  satellite doesn't work after update shulamy 1 884 05-17-2023, 10:34 PM
  Latest update broke my install user641 8 3,706 02-22-2023, 05:54 AM
Last Post: gregb49
  new to pacman. Trying to install VIM, getting a 404 when it tries to download. willyray 1 1,157 12-24-2022, 11:00 PM
Last Post: shulamy
  Waydroid on Arch Linux ARM install guide? tk1107 3 5,597 10-08-2022, 07:46 AM
Last Post: PineFone
  Help to execute script to install arch with FDE user641 5 3,535 07-03-2022, 09:25 PM
Last Post: RTP
