boot order
Hi, love my pbp, Manjaro KDE plasma (last month download) on emmi. Cannot get it to boot from sd. I took off the back cover, switched the emmi off, and was able to boot an sd with Armbian Debian xfce 5. When I replaced cover and rebooted with the emmi switched back on, the sd was ignored again. So, the boot order does not begin with the spi, and then the sd, as stated in the documentation. I suppose that if the spi is blank, the system tries first the emmi and then the sd.
How do I get the sd first order? Isn't that how it is supposed to work? Install what you want on the fast memory and then try out different os's with the sd card, always able to revert to the emmi when the sd card is removed?
This should have an easy fix, but it seems to be a source of confusion to noobies (that's me). Thanks for advice.
boot order - by straightwalker - 07-19-2021, 10:07 PM
RE: boot order - by wdt - 07-19-2021, 11:27 PM
RE: boot order - by jiyong - 07-20-2021, 05:00 AM
RE: boot order - by straightwalker - 07-20-2021, 05:07 PM
RE: boot order - by wdt - 07-20-2021, 06:20 PM
RE: boot order - by straightwalker - 07-21-2021, 11:01 PM
RE: boot order - by wdt - 07-22-2021, 12:31 AM
RE: boot order - by alidonkaka6 - 12-25-2021, 09:23 AM
  uboot wont boot to SD card after upgrade jbradley419 7 780 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 282 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,192 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 672 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 573 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,155 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,850 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 795 07-13-2023, 01:50 PM
Last Post: PaulQ
  Order Status mamboman777 1 3,573 06-17-2023, 10:25 AM
Last Post: fxc
  New Pinebook pro won’t boot Generaltuxenburg 4 1,920 06-14-2023, 07:20 AM
