Install OpenWrt on A64+ without serial?
Well although this is an old thread just to clarify:
You don't need a serial console to set up OpenWrt. Just dd OpenWrt image (current 20.02) to sd and boot up.
There is "Luci" what is the graphical web interface (like on most consumer routers). You can reach it on a LAN interface (in standard configuration its the NIC on A64+) on 192.168.1.1. in your web browser. There you can manage and configure everything in OpenWrt. There is also a ssh server running.
I'm running A64+ with OpenWrt. It works very well! The only issue, if you want to use the upper usb (otg), you need to compile your own image. Should be supported out of the box in the future.
https://forum.pine64.org/showthread.php?tid=13135
RE: Install OpenWrt on A64+ without serial? - by guenther - 12-25-2021, 10:31 AM
  Cannot ship, need USB SERIAL CONSOLE/PROGRAMMER alternative please JuniperFury 5 6,217 10-29-2021, 07:13 AM
Last Post: TRS-80
  OpenWrt and usb guenther 6 7,589 03-09-2021, 07:39 AM
Last Post: guenther
  Is possible to install Home Assistant on pine64 2gb? polv89 1 6,722 04-02-2018, 05:22 PM
  Serial Console: No input KNERD 3 5,307 08-20-2017, 08:21 AM
Last Post: MarkHaysHarris777
  Install Influxdb & Grafana easy mrv 1 3,382 06-30-2017, 10:39 AM
Last Post: xalius
  kodi install on A64, 2GB gychang49 1 4,962 10-02-2016, 07:32 AM
  Install PlayBox Enclosure - pics sarts0703 1 3,072 09-05-2016, 04:29 PM
Last Post: jodybrown99
  Which OS will you install into your Pine 64? 7777777 21 25,736 04-26-2016, 12:19 PM
Last Post: Leoncito81
