For those of us that need a working daily driver
In the case of Halium based builds, UT only uses the drivers from android. The part you know as android is removed and replaced. UT uses aparmour which isolates all apps from each other, so getting compromised, or privacy invaded as Google/Facebook does, is not easy to do. Unfortunately, getting UT up and going on Pinephone/Pinetab is on the backburner until after the 20.04 upgrade. Same with Lomiri.
While you wait, you can try halium based UT, Droidian (Mobian), and Lune on the Nexus 5 for real cheap. Or UT and Droidian on the Nexus 6P or Pixel2 XL for around $100. I just donated my Nexus 5 because although all works, it cannot do VoLTE which has become an issue in the US (although 2G support has been extended until the end of 2022). I own both the N6P and P2XL. My personal recomendation is the P2XL running UT because all works except MMS (it's being worked on). With N6P, all works including MMS except hotspot, and recorded videos must be played back using UT Media Player or other app from the openstore. Otherwise all works, has good battery life, and all three are a joy to use. Join us at UBports Forum or Telegram (Teleports) groups.
But, hang on to your Pinephone because improvements are coming.
RE: For those of us that need a working daily driver - by rocket2nfinity - 07-11-2021, 06:39 PM
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,824 03-09-2024, 11:38 PM
Last Post: dcinoz
  Are you using the Pinephone as your daily driver? jro 157 108,935 02-18-2024, 11:33 PM
Last Post: aular
  are you still using pinephone as a daily driver? zetabeta 29 9,755 02-09-2023, 11:48 AM
Last Post: silverwing
  MMS sending stopped working amindfv 2 1,238 01-16-2023, 09:44 PM
Last Post: treebeard
  Instructions to get pinephone working on USA carrier omarcomputing 1 1,363 10-08-2022, 04:45 PM
  JumpDrive isn't working phytocube 2 1,781 06-05-2022, 03:22 PM
Last Post: phytocube
  SIM card slot not working dekrets 2 2,203 02-12-2022, 11:09 AM
Last Post: dekrets
  Can't get autofocus working duncan_bayne 4 2,927 01-22-2022, 09:17 PM
Last Post: duncan_bayne
  PinePhone Beta 3GB modem not working hannescam 15 9,102 01-19-2022, 02:08 AM
Last Post: bcnaz
  tried it as a daily driver nelstomlinson 18 10,525 01-04-2022, 09:51 AM
