AXP803 Battery Charger Support
The PMIC and battery parameters are actually all read from the devicetree file, so to change them requires only dtc (the device tree compilter). The devicetree files for each board are in the /boot folder (.dtb). The dtc converts the binary back to a text file and creates the new binary from the text file after edits. The parameters correspond more or less to the registers in the AXP803 datasheet. One important thing is, the register settings are persistent as long as the AXP has either input power or battery power! And the linux driver updates the battery parameters only once if the AXP has empty registers. To reset that, all power has to be removed from the AXP. The battery charger only works properly if the battery parameters are persistent, e.g. the battery is not removed, since it is self learning and adapts certain values over charge cycles...
AXP803 Battery Charger Support - by xalius - 06-18-2016, 03:28 AM
RE: AXP803 Battery Charger Support - by tllim - 06-18-2016, 04:16 PM
RE: AXP803 Battery Charger Support - by pfeerick - 06-18-2016, 09:59 PM
RE: AXP803 Battery Charger Support - by xalius - 06-19-2016, 06:19 AM
RE: AXP803 Battery Charger Support - by pfeerick - 06-19-2016, 07:22 PM
RE: AXP803 Battery Charger Support - by tllim - 06-20-2016, 07:38 AM
RE: AXP803 Battery Charger Support - by xalius - 06-19-2016, 07:31 PM
RE: AXP803 Battery Charger Support - by xalius - 06-20-2016, 02:55 PM
RE: AXP803 Battery Charger Support - by longsleep - 06-20-2016, 04:25 PM
RE: AXP803 Battery Charger Support - by drid - 12-03-2017, 02:24 PM
RE: AXP803 Battery Charger Support - by xalius - 12-03-2017, 03:56 PM
RE: AXP803 Battery Charger Support - by xalius - 12-22-2017, 05:23 AM
  Programming languages support under PINE64 baryluk 6 12,064 09-23-2020, 11:46 PM
Last Post: Phillip Bell
Wink Pine64 Will support Freenas or openmediavault ? joe 1 4,907 04-13-2017, 07:44 AM
Last Post: xalius
  Remote Desktop Support? Rochambeaux 20 28,732 10-01-2016, 05:08 PM
Last Post: HayseedGeek
  Binfmt_misc support cztian 1 3,637 08-17-2016, 11:49 PM
Last Post: longsleep
Question Joystick/Gamepad support Drakuwa 3 5,850 08-10-2016, 10:12 AM
Last Post: xalius
Big Grin Funny ! Support Intel x86 linux applications on ARM-based ( PINE64 ) not freeware joe 10 16,054 08-09-2016, 05:59 PM
Last Post: dkryder
  Camera support - Ubuntu Xenial 16.04 LTS @lex 3 5,103 08-07-2016, 03:47 AM
Last Post: romansavrulin
  Virtualization Support soccercheng 12 17,015 07-14-2016, 11:04 AM
Last Post: mont3z
  distro with kernel support for DVB-T dongles? mkaut 2 4,533 07-02-2016, 02:36 PM
Last Post: mkaut
  XFS Support? utdrmac 2 3,263 06-30-2016, 01:44 AM
