Pine64 + waveshare display?
(06-18-2016, 04:00 PM)iPhyse Wrote:
(06-16-2016, 05:02 PM)xalius Wrote: Hi! Did you read http://forum.pine64.org/showthread.php?tid=980 for switching resolutions? You have to make sure that the HDMI output matches something your display can support, I am not sure if your display's resolution is a supported mode atm... check here https://github.com/longsleep/sunxi-disp-...tput-names
Thanks for your respond. But despite of your references the solution did not work for me, as so far. none of the both options won't display more than a black striped noise:
cat <<EOF| sudo tee -a /boot/uEnv.txt
optargs=disp.screen0_output_mode=480p //or i
EOF
sunxi-disp-tool switch -mode 0
sunxi-disp-tool switch -mode 2
But the strange thing is that the pi just works straight ahead..
If I take a view to the config, which are available on the rpi2, the /boot/config.txt would give me the opportunity to set some config according to my hdmi output for my display..
#hdmi_force_hotplug=1 //disabled
hdmi_group=2
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
resolution 800 x 480,
refresh 60Hz,
aspect ratio 15:9,
no margins,
no interlace,
normal blanking
It doesn't even matter to me if the touch function is working or not.. But only a output to the display is enough Smile
i have the same problem. can someone help steer me the right way
Pine64 + waveshare display? - by iPhyse - 06-16-2016, 04:43 PM
RE: Pine64 + waveshare display? - by xalius - 06-16-2016, 05:02 PM
RE: Pine64 + waveshare display? - by iPhyse - 06-18-2016, 04:00 PM
RE: Pine64 + waveshare display? - by hamzahbondok - 10-12-2016, 04:43 PM
RE: Pine64 + waveshare display? - by tllim - 06-17-2016, 10:09 AM
Question External storage problem for pine64 Dani6102 4 1,618 08-22-2023, 08:36 AM
Last Post: gulshan212
  Pine64 as wireless audio device S265 3 3,158 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,110 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,326 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,091 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,741 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 4,898 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,804 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,515 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 7,162 05-03-2019, 02:48 PM
Last Post: Mendota
