The state of mainline hardware decoding
Previously I had H.264 decoding working on a 5.10.17 kernel with patches from Pine64 (pbp-tools) for an rk3399.  We had a need to bump to 5.15.14 so I needed to update the decoding stuff, plus get MJPEG encoding working.
I found that the old patches are no longer valid.  The upstreamed rkvdec driver in 5.15.14 works (unpatched) for H.264 decoding using the ffmpeg for xbmc (tag: 4.4-N-Alpha1) plus the LibreELEC patches.  I can decode 4 streams of RTSP, output to null, at 30fps with about 6% CPU usage.  Without hardware decoding this would have been over 25% CPU usage.  The command I used for this test is as shown.
Quote:ffmpeg -y  -hwaccel drm -hwaccel_device /dev/dri/renderD128  -rtsp_transport tcp -i rtsp://192.168.101.47/stream1  -rtsp_transport tcp -i rtsp://192.168.101.47/stream1  -rtsp_transport tcp -i rtsp://192.168.101.47/stream1  -rtsp_transport tcp -i rtsp://192.168.101.47/stream1 -threads 1 -f null -
I have not been able to get MJPEG encoding working.  This is my test command, which may not be correct.
Quote:ffmpeg -y \
-hwaccel drm \
-hwaccel_device /dev/dri/renderD128 \
-rtsp_transport tcp \
-i rtsp://192.168.101.47/stream1 \
-c:v mjpeg_vaapi -q:v 10 -an -y -frames 900 -vsync 2 \
This command fails.
Quote:Stream mapping:
  Stream #0:0 -> #0:0 (h264 (native) -> mjpeg (mjpeg_vaapi))
Press [q] to stop, [?] for help
[h264 @ 0x19969a10] v4l2_request_try_format: pixelformat 875967059 not supported for type 10
[h264 @ 0x19969a10] v4l2_request_probe_video_device: try output format failed
[h264 @ 0x19969a10] v4l2_request_probe_video_device: set controls failed, Invalid argument (22)
Impossible to convert between the formats supported by the filter 'Parsed_null_0' and the filter 'auto_scaler_0'
Error reinitializing filters!
Failed to inject frame into filter network: Function not implemented
Error while processing the decoded data for stream #0:0
Conversion failed!
Changing the output codec to mjpeg just gets me a CPU-based encoding, so CPU usage goes up to around 25%.
There is ony one v4l2 JPEG controls on the video1 (and none on video2) device but I'm not sure that implies MJPEG support.
Quote:$ v4l2-ctl --list-devices
rockchip,rk3399-vpu-enc (platform: hantro-vpu):
        /dev/video1
        /dev/video2
        /dev/media1
rkvdec (platform:rkvdec):
        /dev/video0
        /dev/media0
$ v4l2-ctl --list-ctrls --device /dev/video1 | grep -i jpeg
JPEG Compression Controls
There is a recent patch for 5.18.x that may improve this but I don't see any additional controls in the patch.  I have not applied the patch or attempted backporting it yet.
If anyone has additional information on the state of mjpeg encoding and/or appropriate tests to use let me know.  Thanks.
Michael J. Hammel
mjhammel@graphics-muse.org
michaelhammel@acm.org
RE: The state of mainline hardware decoding - by mjhammel - 01-26-2022, 12:33 PM
Information Linux Mainline ayufan 63 90,179 05-14-2021, 10:41 AM
Last Post: Wizzard
  Hardware acceleration using FFmpeg gusarg81 0 2,817 08-21-2020, 01:36 PM
Last Post: gusarg81
  mainline kernel sound support Openwrt lucize 2 3,990 05-01-2020, 05:09 PM
Last Post: PakoSt
  Hardware Status Monitoring? Leapo 7 14,884 03-15-2020, 08:44 AM
Last Post: bendem
  Any advantages to using the mainline kernel dkebler 0 2,081 11-16-2019, 12:17 PM
Last Post: dkebler
  Does anybody run the mainline kernel? CameronNemo 3 4,558 09-09-2019, 07:56 PM
Last Post: CameronNemo
  hardware-accelerated video transcoding (Plex) on Rock64 mdr 2 7,217 02-07-2019, 03:42 PM
Last Post: mdr
  Updates on Mainline Linux Support? hnaguski 0 2,433 09-11-2018, 08:16 PM
Last Post: hnaguski
  How to do hardware decoding of video? SuperSaiyanCaleb 9 15,366 08-28-2018, 01:39 PM
Last Post: mcerveny
  H264 hardware encoder not work sueshieh 3 6,426 11-02-2017, 03:57 AM
Last Post: dalmate
