Arrived today...cannot boot to touchscreen or HDMI?
(06-16-2016, 07:14 AM)Ghost Wrote:
(06-16-2016, 07:13 AM)editfish Wrote:
(06-16-2016, 07:09 AM)Ghost Wrote: I believe Android utilises an EXT4 file system, which is not natively recognised by Windows or OS X, so they will not recognise the data on the microSD and may ask to format it.
Thanks, Ghost.  That makes sense, but I'm still unsure how to proceed with the start up?  Does it require a network connection to boot?
Network connection should not be required. You can try re-burning the OS image. Image files available here:
http://wiki.pine64.org/index.php/Pine_A6...re_Release
Note that LCD Touchscreen and HDMI connection methods require different OS images.
So I have my Pine working - pretty well, actually, while hooked up to my TV.  I've been trying to get it to work with the 7" touchscreen I ordered at the same time with no luck.  Poking around here on the forum I come across your statement above - that the two screens require different OSs.  I can live with that until some method or OS that allows either to be used interchangably.  I got the 64Gb card with Android already installed / flashed, is there a way to have multiple OSs on the same card so that I can use whichever I'd like?  Is there a way to do this while maintaining other settings and files?
Thanks for anyone's thoughts on this.
Whoops - checked out the Android Touchscreen/HDMI thread (Severian) and found the answers there!
RE: Arrived today...cannot boot to touchscreen or HDMI? - by 84thProblem - 07-02-2016, 10:04 AM
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,138 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,577 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,558 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,691 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,056 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,224 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,144 10-18-2020, 01:41 PM
Last Post: toiny
  SD Card boot - trying out OS Baconomics 1 4,365 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,454 03-18-2020, 09:42 AM
  Pine HDMI -> DVI monitor Pineapple 4 7,780 09-10-2019, 11:28 AM
Last Post: Pineapple
